Question about Adaptec 29320 SCSI Controller
Getting the following error repeatedly: A parity error was detected on \Device\RaidPort1. Source: adpu320 Event ID: 5 Any help would be greatly appreciated...
Posted by tcm007 on
SirEbrum
    New Friend:
    Problem Solver:
  • 6 Answers
Any "Parity Error" is from a communication error on the SCSI bus, and it's bad! Errors are a way of life, and the SCSI transceiver has failsafes to fight them, and one of these is parity. Consider it extra data that the controller sends when you transfer data to your hard disks. Once there, the drives transceiver does a simple ccheck and verifies that the parity is correct. If not, a Parity Error is generated.
99% of the problems surround the SCSI bus itself in the form of a damaged SCSI cable, loose terminator, or a bent pin on a SCSI connector (latter being most common). This error is more apparent after moving the SCSI devices, resulting in unplugging and then replugging the cables back onto the Targets (HDD, CD/DVD ROM, printer, etc.) or back onto the Host Bus Adapter (HBA - the 29320 in your case). Check ALL pins. You can try to straighten the pins, otherwise it's time to replace the cable. REMEMBER that terminators are a must and can also cause Parity Errors if there is no termination present on one end of the bus or the other.
This coming from an ex-Adaptec employee and support person! :)
Best of luck
Posted on Oct 28, 2011
Error event
Your power supply is not providing the correct voltage, it needs replacing.
Feb 23, 2010 | Dell PowerEdge 2650 Motherboard 533mhz FSB...
Inspiron 8500 laptop (80GB) intermittant boot failure
Hi
Thank you for your query
If there is a clicking noise inside then the hard drive is on the way out, the arm that reads the data is knocking against the plates, thus the noise
I would recommned that you back your data as soon as possible as the drive will eventually fail
Please can i ask that you leave feedback and vote if this has been useful
Feb 12, 2010 | Dell Hard Drive for Inspiron 8500 and 8600...
HP 8200e CD Writer not recognized by Windows XP
You can access these logs here:
Right click on "My Computer", scroll down and click on "Manage"
This will open your "Computer management" window.
On the left side you will see "Event viewer".
Click on the plus sign and it will open the log files. The ones you want to look at will be Application or System.
Now, if you see an error, double click on it and a window will open. Pay close attention to the "Source, Category and Event ID" names and numbers.
Now with the Event ID number, go to this site: http://www.eventid.net/
Plug in your data and do a search.
It may help to tell you why the computer is crashing when inserting disks.
Hope this helps.
Oct 20, 2009 | HP CD-Writer Plus 8200e (C4454A#ABA)...
Hard Disk Problem
it seems as serious disk drive error to try fixing any errors that may be present on drive please run from command prompt [as admin] cd /D <faulty drive letter> then chkdsk /r if asks to unmount <or scan after reboot if it is sys disk> say Yes <lonely Y also does the job> this should fix the trouble, if not please send message
Oct 09, 2009 | Computers & Internet
1 Adaptec RAID 3085 cause parity error in server while 2nd don't!
I'm thinking you should be checking the drives. If one of them is failing, you will get parity errors.
Picking apart parity problems TechRepublic
Mar 04, 2017 | Acer Altos G530 Server
Computer will not start
When Windows crashes with blue screen, it writes a system event 1001 or 1003 and a minidump to the folder \windows\minidump. Check system event 1001 and 1003 and it has the content of the blue screen
Event ID: 1001
Source: Save Dump
Description:
The computer has rebooted from a bugcheck.The bugcheck was : 0xc000000a (0xe1270188, 0x00000002, 0x00000000, 0x804032100).
Microsoft Windows..... A dump was saved in: .......
Event Source: System Error
Event Category: (102)
Event ID: 1003
Description:
Error code 1000007f, parameter1 0000000d, parameter2 00000000, parameter3 00000000, parameter4 00000000
Control Panel -> Adminstrative Tools -> Event Viewer -> System -> Event 1001/1003. Copy the content and paste it back here
Aug 17, 2008 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Event ID 11 error
Wonderign if you tried to install this on the RAID controller....big nono and cause this very issue...try a different SCSI controller...hopefully you ahve one onboard NOT raid. hope that helps
Aug 17, 2007 | Sony AIT Library LIB 152E/A1 (LIB-152E/A1)...
Adaptec 29320 SCSI Controller Logo
6,623 people viewed this question
Top Adaptec Computers & Internet Experts
John Dio
Level 1 Expert
Robert Graf
efs_perpends
efs_perpends
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
