Typically the barbed port where the induced draft proving switch's tubing connects gets obstructed by carbon , if you ream out the port on the induced draft assembly it will allow the induced drafts switch to sense the draft motor is operational, this port needs to be reamed annually to avoid this.Typically the barbed port where the induced draft proving switch's tubing connects gets obstructed by carbon , if you ream out the port on the induced draft assembly it will allow the induced drafts switch to sense the draft motor is operational, this port needs to be reamed annually to avoid this.
Posted on Apr 07, 2015
Hello, it sounds like the pressure switch is not closing on your furnace and remaining open, reasons for this could be a blocked flue pipe, the tubing going from the inducer motor to pressure switch could be blocked, loose, or have condensation in it, or the switch itself is bad. U can check the tubing by taking it off blowing some air through it and making sure no condensation is in the tubing, then reinstall it. If everything checks out good then the pressure switch is bad and must be replaced.
Posted on Mar 02, 2011
Jan 31, 2015 | Heating & Cooling
Jul 18, 2014 | Mitsubishi WD Televison & Video
Nov 28, 2013 | Sony Televison & Video
Jun 18, 2012 | Hitachi Heating & Cooling
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Dec 14, 2010 | Heating & Cooling
Aug 04, 2010 | 1996 Dodge Neon
Jan 06, 2010 | Goodman GMS90703BXA Heater
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Nov 13, 2008 | AEG Lavamat W1050 Front Load Washer
245 people viewed this question
