Question about Zebra Eltron LP 2824 Thermal Printer
I wish to connect a bar code scanner to my Keyboard Display Unit for inputting data when printing labels. Can you provide information relating to pin outs, protocols and how to set this up? Thanks
Posted by pawood875 on
Michael OGrady
    New Friend:
  • 22 Answers
By Keyboard / Display unit I'm assuming your using a PC, thin client or dumb terminal. If you are using a PC then the easiest way to do this is to get a bar-code scanner with a USB interface, no programming should be required with possibly the exception being of adding a "Enter" (CR LR) after each scan.
If you have a dumb terminal then you may need to look at trying to use an RS232 connection (if one exists) or a keyboard wedge solution where the scanner is plugged into the keyboard port along with the keyboard.
In any event pin outs would vary depending upon the scanner you want to use and the device you are connecting the scanner to.
Hope this helps
[email protected]
Posted on Mar 02, 2011
Symbol Model LS 9208, Bar code Scanner loaded factory setting, its scans(beeps) but does not display /show in the notepad.
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Aug 21, 2010 | Symbol LS9208 Hands Free Barcode Scanner
Tip
How do I read Barcodes in Microsoft Excel?
<p>Bar code symbols are composed of a number of adjacent bars and spaces of different widths of pre-defined codes. A barcode scanner is used to read or scan the bar code symbol to represent the information to decode. Once the symbol is scanned by a handheld reading device or another, can then be used by computer software to track inventory and perform other functions. Microsoft Excel is a computer application that use bar code information can make the business perform. <br /> <p><br /> <p>1. Insert bar code scanner to your computer using the "interface cable keyboard wedge". The keyboard wedge interface cable looks like the printer port of your computer, and differs only in that a connection between the scanner bar code and serial number of your computer or USB port. The cable is provided as a peripheral pattern with hand-held bar code scanners. <br /> <p><br /> <p>2. Open Microsoft Excel on your computer after the bar code scanner connected to your computer. <br /> <p><br /> <p>3. Links on the Excel cell to the bar code to enter and bar code scanning to load it into Microsoft Excel. <br /> <p><br /> <p>4. View the data in Excel file is translated into a vision of the bar code information. <br />
on Jun 26, 2011 | Computers & Internet
Tip
How to change settings on a barcode
<p>Barcodes can be printed symbols encoded information printed in black and white contain. You can use bar codes entering data into bar code - the generation of the image software and print barcode using a normal printer or a barcode printer. Printed bar codes are read by a barcode scanner that reflected light rays used to decipher the code. Bar codes may contain different information. You can change or a bar code can be adapted by entering the information reviewed in the bar code - generation software. <br /> <p><br /> <p>1. Access your favorite browser and go to barcode generator, barcode, bar code or soft (see Resources) can use a free barcode - generation software. <br /> <p><br /> <p>2. Most sites that offer bar code - generation software to present their application interface on their own pages. Enter the information reviewed or custom code in the space you want, and "Generate Barcode" button to click to create barcode images. <br /> <p><br /> <p>3. See the image of the barcode displayed on your computer, click on the image to pop-up menu to display. Click "Save Picture As" from the pop-up window, select the location where you want to save the image and click "Save" next window to save the image in the selected folder. <br /> <p><br /> <p>4. Connect the cable to patch your bar code scanner in its corresponding port on the back of your computer. Keep the scanner about six inches from the printed barcode, which focuses on the barcode and press the button to scan the bar code. Look at the revised data upload to your computer and check its accuracy. <br />
Could not active it the scanner on the MC9090
The link works for me DataWedge provides a convenient mechanism for non-scanning aware applications to receive data from embedded or connected data capture devices. It allows the user to capture data into any application that accepts keyboard input. It supports four types of Data Feeds: Barcode Scanners, RFID Tag Readers, MSR Readers and Serial Data Input. It provides user with text/hex data formatting and prefix/suffix facilities. Description
  1. New Test and Log Display.
  2. Improved DataWedge Startup Time for MSR and RFID
  3. Gen2 RFID Support
  4. Device enable/disable persistence over cold boot
  5. Virtual Key Support in Prefix/Suffix
  6. Performance improvements for MSR
  7. Enable Serial Interface on startup
  8. Support added for Event based Serial reading.
  9. Delays regarding RFID are fixed.
  10. Several Barcode character mapping issues fixed.
make sure some security software is not blocking your access
Jun 22, 2009 | Symbol MC9090 Barcode Scanner
Skips Bar Code Labels
It could be software related.  The best way to find out is to restart the computer where the labels are coming from.  Turn your printer off and back on again as well.  Run the program that loads the forms into the printer to print with.
Is the printer on an ethernet connection or is it connected to a computer?
Oct 21, 2008 | Zebra Z4Mplus Label Printer
Tip
How do I create a UPC Code Labels?
<p>Universal Product Code (UPC barcode) is numeric, computer-readable tags used to track products in a store or warehouse. GS1 is the only body that the numbers of the original UPC barcode can give companies in the United States. The acquisition of authentic bar code numbers for your UPC labels, you need a partner and GS1 bar code numbers for your payments. <br /> <p><br /> <p>1. Suppose your company expects annual turnover, number of products that will sell that require UPC bar codes, contact information and your business. <br /> <p><br /> <p>2. Go to the site of GS1 and GS1 U.S., apply for the program Connections partners. Pay your membership online by credit card, or follow the instructions as part of an application to send a check. <br /> <p><br /> <p>3. Log on to the GS1 site a day after your membership is processed to determine your company's prefix number. This number is unique to your company and is an essential part of your bar code numbers. His company prefix, the first 2-6 numbers of the barcode. Download your number of UPC bar code on the site of GS1. <br /> <p><br /> <p>4. Print your labels, UPC bar code at home or third company to print. You can choose to print bar codes directly on the product packaging. <br /> <p><br /> <p>5. Make sure your UPC barcode labels and height requirements for the color of GS1 distribution of your product needs. Labels that do not meet these requirements cannot be read by machines, bar code scanner. <br />
Tip
How do I adjust Barcode on the price tickets?
<p> <p> <p>Bar codes are created using the software to generate bar code and printed on price tags with bar code printers. Tickets barcode typically contain product information and pricing, but there are times when prices should be adjusted to produce a product more salable. Establish a barcode on a price tag, generating a new image of the barcode using a computer, print the barcode image and paste the image printed on the sticker price. <br /> <p><br /> <p>1. A site of a software program that allows you to create an image of the barcode (see Resources) to download. <br /> <p><br /> <p>2. See the homepage of the site and watch the program interface. Choose the type of barcode you want to generate from the list displayed. Enter the information you want to encode the space provided. Click "Generate barcodes" to create barcode images. See the image and right click on it to a drop-down menu to display. Click "Save image as" the image of the barcode on your local computer store. <br /> <p><br /> <p>3. Place a sheet of paper label on the computer printer. Open the folder where the image of the barcode. Right-click on the image of the barcode that you saved and click on "Print" from the menu bar to print. <br /> <p><br /> <p>4. Cut the bar code printed on the price tag to match, and stick it in the bar code on the old price. Scan the barcode with a barcode scanner and check the data sent to your computer. <br />
Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Aug 16, 2007 | Metrologic Instruments 9520 Voyager
Tip
How do I create custom Barcodes?
<p>Barcodes can be printed symbols with encoded data will be charged to the computer via a scanner. A bar code allows a company to maintain control of their actions to secure and instant access to information about each product. A bar code is created using software barcode generation software. Customizing a bar code is a simple process to enter your data into the software program, and print.<br /> <p> <br /> <p>1. Open your Web browser and visit Barcode Generator, barcode or Soft. See the program's interface is usually presented on the homepage of the website page. Look at the list of different types of bar codes available, and click the type of barcode you want to use. <br /> <p><br /> <p>2. Locate the area where you are allowed to present the information is converted into a bar in, and within the data type. Click "Generate Barcode" to create barcode images. View the image resulting bar code, right click on the image and click "Save image as" in the drop-down menu to save the resulting image on your computer. <br /> <p><br /> <p>3. Close the program bar code generation, and open the bar code image stored on your computer. Right click on the saved image and click "Print" from the output drop-down menu to print the bar code. Scan the bar code information printed to be loaded on your computer and check the data sent to make sure it is correct. <br />
Tip
How to install a barcode
<p>Bar codes are images that data can be scanned and read by computers and other devices contain. They usually appear on the packaging as black lines that are scanned when you buy the products, but they can come in various shapes and used for many different purposes. Creating a bar code means to make the image bar code using special software, prints it and attaches it to the relevant item. <br /> <p><br /> <p>1. Surfing the Internet for sites that offer free services for creating barcodes (see Resources). <br /> <p><br /> <p>2. Open the Web page Most of these sites offer the ability to create different types of barcodes. If so, select the one you want by clicking on it. <br /> <p><br /> <p>3. Type the information that is encoded in a barcode field or space provided. Look for a button or link to the bar code and click generate. See the image of the barcode that results when displayed. Right-click the image to the browser's drop down menu and select "Save Image As" to save the image on your computer. <br /> <p><br /> <p>4. Open the barcode image and printing the image using sticky paper. Connecting a bar code scanner to the serial port or USB port of your computer and scan the bar code printed. Check the information sent to your computer to verify its accuracy. Cut out the barcode labels remove the patch and attach it to the item or product. <br />
Zebra Eltron LP 2824 Thermal Printer Logo
75 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Ekse
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
