Question about Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive
Hello my usb stick 4 Gb doesn't work. When I put it in PC on My Computer it's shown as a removable disk and when I want to look into the drive it shows "disk is not formatted, do you bwant to format". When I look in properties of the drive it shown as if the USB stick is full with data, but that isn't so. Can you give me some advice what to do? Thanks already for the info, Erik Tummers
Posted by erik_tummers on
  • 3 more comments
  • erik_tummers Mar 02, 2011
    OK that's strange, used it only 2 times, anyway thanks for the info
    On every pc or laptop I get the same messages, so I think I this usb-stick is made on a mondaymorning waha
    Hello Franzer, it didn't work, when I open the window on diskmanagement it shows the usb-stick as a removabe disk with 8 MB of healthy space and when I want to format a new FAT32 partiton it says "the format does not complete succesfully"
    Thanks for the help and I will go back to the store and hope they will help because I don't have the bill anymore, we will see, anyway great for the fast reactions
    Sorry for that, I changed it already, I thought it was a symbol for the result of the given solutions but it is a ranking for the expert, now I know. Good work.
Franzer
    Scholar:
  • 87 Answers
that error usually appears when Windows is unable to read the filesytem of an hard drive. It can be caused by unsupported or corrupted file system. You should try to format your pen drive using either a free/windows utility, or using DOS command lines (Start>Run>CMD>format *driveletter*: without stars).
Hope it helped,
Franz
Posted on Mar 02, 2011
Testimonial: "Thanks for the info and advice, good work"
    Hello Thanks but it didn't work. I got message that the files are is RAW? what does that mean and what's a solution?
  • Franzer Mar 02, 2011
    Then you should try to create a new partition on it. To do so go to Control Panel>Administrative Tools>Computer Management and, on the left you will find Disk Managament. There you need to create a new FAT32 or NTFS partition and sees if that works. Let me know!:)
Brian Sullivan
  • Dane-Elec Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
also
I would tick in one box automatically fix files then return after it has repaired then tick the other box
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start or you might tick one box then return after its finished the first repair the tick the second box
hope this helps don
  • 1 more comment
  • Brian Sullivan
    Brian Sullivan Mar 02, 2011
    USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
    click Start>run>regedit to open Registry Editor. and press control F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
    # Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
    also
    If you are running a Windows XP OS then you might be able to:
    - click start right click on my computer select open
    - Right click the icon of your Flash Drive (It should be F:/ or something)
    - Click Properties in the menu that comes up
    - Click the Sharing tab
    - Click permissions
    - And finally, click Allow next to Full Control.
  • Brian Sullivan
    did you try this
    click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start you will see two boxes.
    hope this will help you
    Hello, it didn't work, I dont know why it shows healthy and for only 8MB of free space on a 4 GB usb-stick?
enanti
    New Friend:
  • 18 Answers
When it asks if you want to format it choose yes.
    I got everytime error message "Windows was unable to format the drive"?
Fred Flintstone
    New Friend:
  • 76 Answers
You need to format the USB disk.
You can do that in My Computer by right clicking the disk in My Computer and then select format.
  • 3 more comments
  • Fred Flintstone Mar 02, 2011
    Sounds like your pen drive burned out then. Time for a new one. Try it on another computer if you can as a last ditch effort.
    I'm sorry to hear that. Your USB stick should have some sort of warranty if it's under 90 days old.
    Curious, why did you downrank?
    Thank you =)
How do i get to unwrite a write protected thumb drive?
Try this:
1. Put in your USB stick 2. Right click "My Computer" and select "Manage" 3. Expand "Storage" and go to "Disk Management" 4. Right click your USB drive (i.e DISK X down the bottom) and select "Properties" 5. Select "Policies" tab and select "Optimise for Performance" 6. Click "Ok" to save.
But in the most likelihood, your drive has reached its write limit (i.e. broken)
Regards
Sep 19, 2011 | Computers & Internet
I have a vaio sony 4 GB flash disk when i try to put pics and song and videos in it it works for some min and in the same computer but when i try to put it to another pc after playing the video it says can...
Hello
theres a few things you can do, when you do format your memory stick make sure you format it to the default settings.
Also make sure everytime you put files onto your memory stick that you remove the memory stick safely you can do this by right clicking the memory stick and pressing eject.
However the problem could be that your memory stick is corrupt.
Jul 13, 2011 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Hello...after moving pc and take of power of WD Elements 400, it didn't show up anymore in the My Computer screen and doesn't seem to work...no sound, just the burning blue light..what to do?
Disassemble the case, and remove the 400GB disk-drive.
Connect the disk-drive as a "slave" disk-drive to some desktop computer, and see if you can still access the files.
Get the serial-number from the label on the top of the disk-drive, and access Western Digital's web-site, to check if the device is still under warranty. If it is, W.D. will replace it, at minimal cost to you.
If the warranty has expired, W.D. has a "Customer Loyalty" program -- you can buy another external disk-drive from W.D.'s web-site, at a significant discount.
May 08, 2011 | Western Digital Elements (WDE1U4000N) 400...
My flash disc is unrecognized by the pc
Try inserting it into a different USB port, or try one on a different computer. If that doesn't work, you'll have to resort to formatting the disk to continue using this flash drive. (Formatting deletes all the data on the disk though).
May 04, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do you use usb sticks?
1. Plug thumb drive or USB into the USB port on the laptop.
2. Go to My computer and see if you see "Removable Disk" if yes then you double click here and you will see the contents of the USB drive.
3. load something from the laptop or PC to the usb just drag document or program from PC drive to usb drive.
4.Go to site called "Ehow" to gain more information.
Note of caution donot just pull USB from the usb port it will erase all the information and the USB drive will then be rendered usless.
5. Remove USB in the proper manner that is goto the "task bar and look for the "safe to remove hardware" icon or go to the "my computer" icon select the "removable disk" icon ( right click) and the select "eject" if the drive is busy or a message comes up that it is then closed all programs associated to it and the "Eject" the drive and remove it from the USB port.
I hope this helps. Have a good day!
Jul 09, 2010 | Dell Studio 1737 Laptop
Can't read Kingston DTI/4 GB flash drive
you have to see in witch format is the stick mostly is FAT32 but normaly you dont need to format just when is some video on it,from my experience reinstal the drivers and i mean all.
Nov 04, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
16 GB USB 2 MEMORY STICK I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem...
I'm a little confused as you mention both Drive E. which suggests Windows and gnome which suggest linux.
WARNING: Formatting the disk will erase any data on it. Do not format the disk if you are trying to get the data off it that was on it yesterday.
It is possible that the partition table has been corrupted.
If you are using windows. You can either try right clicking on the drive (not double clicking) from Windows Explorer (My Computer) and clicking format. Choose the file system type and go. Alternatively, you could work through the disk management administrative tool. Right Click on My Computer -> Manage -> Disk Management. Right click on the volume and format it.
If you are using linux, see if you have a valid partition table using fdisk for the device. Then, after creating the partition, use mkdosfs to format the drive. If you have formatted the drive as a linux partition, such as ext2, ext3, or reiserfs, it is likely that Windows will not see it as a valid drive.
Jun 02, 2009 | Electronics - Others
Computer keeps on telling me "please insert a disk into drive E:"
try to rerfresh on MY COMPUTER then it will appear on E, if it won't open, right click then Explore.
May 07, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Usb not recognized when I put scan disk in port
do 1 thing plug it on a other PC or on a mac and see what happens !!
then format the volume..
hope this helped...!!
Feb 28, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Dane-Elec DaneElec 4GB USB Drive Copper Hard Drive Logo
1,094 people viewed this question
Top Dane-Elec Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
L Vincent Testa
L Vincent Testa
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
