Question about Nintendo Wii Fit - Balance Board + Game Console
My wii balance board was submerged under water when my basement flooded. Is there any way it can be saved?
Posted by dlevy_orders on
Fred Flintstone
    New Friend:
  • 76 Answers
If it just happened, submerge the whole thing into dry, uncooked rice. Leave it sit for 24-36 hours.
This is not guaranteed to work, but it has been known to save some cellular phones.
Posted on Mar 02, 2011
Jon Nichols
    New Friend:
  • 30 Answers
If you haven't turned it on since the accident...it might be possible. Firstly, you will need to try and get all of the water out of it as possible. I've heard that rice helps get water out of cell phones that have been submerged...but for a device that large, it would require a large box and a large bag of rice (a few pounds).
The problem is that if you try to turn it on while it's still wet inside it could cause a short circuit. Avoid turning it on until all the components are dry.
If you want to try the rice trick, find a large box to put the board in, then get a large bag of rice and dump it over the board. Leave it set for a few days. The rice soaks up the moisture. You need enough rice to completely cover the board so it can't be seen at all. I know it sounds silly....but it works with smaller devices.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jonathon_2815d94e62f0ea08
Why wont the motor on a top load roper washer work after a flood
If the motor was submerged in water it's probably shot. They aren't made to function during and after exposure to water.
May 20, 2014 | Roper RAS8445KQ Top Load Washer
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
How can i re connect the wii fit balance board to my wii ?
Synching can be completed only if a compatible game disc is running in the console. Compatible game discs (such as Wii Fit) will display the Wii Balance Board icon on their packaging.
The Wii Balance Board must be synced to each compatible game individually.
Follow these directions to sync the Wii Balance Board (so that it is recognized by the Wii console):
Insert a Wii Balance Board compatible game disc (such as Wii Fit) in the Wii console.
Mar 16, 2011 | Nintendo Wii Console
How do you sync the wii fit board and wii console
  • Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
  • Insert a Wii Balance Board compatible game into the Wii system.
  • Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
  • Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
  • Turn the Wii Balance Board upside down.
  • Remove the battery cover under the balance board to reveal another sync button.
  • Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
  • Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
  • Mar 03, 2011 | Nintendo Wii Console
    Basement flooded, combustion air flap employed.any way to repair?
    So you had water enter the burner combustion chamber through the access panel. That can be cleaned out, but was the gas control valve just above it on the water heater submerged under water as well? If so, do not use it or try to repair it. It is unsafe to use and the control must be replaced. Now whether or not it's worth while to replace just the gas control, depends on the age and condition of the water heater itself. Also, is this covered under your home owner's insurance policy? Damage from flooding is usually not covered in a standard policy,unless you had it added specifically. But it is covered if you had a water line break which resulted in the water damage. You should find out before you proceed with changing the control. We had the latter occur and our insurance co (State Farm) covered everything from clean-up to replacement). Hope that helps. Douglas
    Jun 15, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
    Dryer wet due to flooded basement
    if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
    Apr 30, 2009 | Kenmore 62602 Electric Dryer
    Balance board not working
    Ok So now
    U need to sync your balance board
    The same way u do it 4 ya wiimotes
    U kno
    press sync in the front of the wii an also under ur balance board hold the one in th front of the wii but release the one in the balance board til it works
    Nov 16, 2008 | Nintendo Wii Console
    Flood
    You have more than one board that got water on it. Most likely a lost cause. Check with home owners insurance for repair or replacment value.
    Feb 18, 2007 | JVC AV-56WP30 56" Rear Projection...
    Nintendo Wii Fit - Balance Board + Game Console Logo
    81 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Lee Hodgson
    Lee Hodgson
    Anon
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
