It is most likely that the pinch roller will need replacing. Once these become glazed (shiny) the tape slips over them, resulting in 'chewing' as the edges of the tape ride up or down the capstan shaft and into the top or base 'rabbit' of the exit guide nearby. Replace the roller, clean the tape path (capstan, guides, heads, take up arm, etc., *gently of course*) with alcohol solution or methylated spirit - do not use q-tips to clean the drum.
VCR should be OK after that. No further repair should be necessary here, and rubber pinch rollers for VCRs are not expensive to order as a generic part for this model.
