Question about VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard
Can you tell what are the compatible processor for motherboard p4m800-m v:1.0a
Posted by bulletant72 on
Anonymous
    Scholar:
  • 105 Answers
This motherboard supports Intel Pentium 4 processors which are made for socket 478.
If you visit this webpage: http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=453&DetailName=Feature&MenuID=24&LanID=0
And scroll down to the bottom there is a list of the CPUs that it supports.
Hope this helps, please rate my answer :)
Chris
Posted on Mar 02, 2011
5 Related Answers
Anonymous
  • 2351 Answers
SOURCE: motherboard P4M800-M7
Microsoft has a program that will run on your current PC. It will check & confirm if your system can handel Vista. It will also show you what is not compatible with Vista. It will check every piece of hardware including your board & even your printer if it's connected & turned on.
It's a must use program for people who are thinking of installing Vista.
Click the link provided: http://www.microsoft.com/windows/products/windowsvista/buyorupgrade/upgradeadvisor.mspx
Than click Download Windows Vista Upgrade Advisor
Good luck...
& please vote.... Thanks
Posted on Mar 07, 2008
leecom72
Lee Hodgson
  • 4810 Answers
SOURCE: looking for compatible processor for biostar
Hi there.
Your board is a socket 775, also called Socket T or LGA775, is a Land Grid Array (LGA) socket used for the most recent generations of desktop Intel microprocessors starting from Pentium 4 and up to Core 2 Quad / Core 2 Extreme families. The socket LGA775 supports Intel CPUs from 1.8 to 3.8 GHz with Front-Side Bus frequencies ranging from 533 MHz to 1600 MHz.
Its up to you which type of processor you get but now you have the general idea.
Good luck and thanks for using FixYa!!
Posted on Mar 05, 2009
Chinthakaj
ChinthakaJ
  • 943 Answers
SOURCE: MOTHERBOARDS Compatibility with this processor model.
the model you have given is not the correct model Number. Please check the link below & see where it says " E2160" this is the model number for the Intel CPU. please chk on your CPU & let me know the model you have. also most intel motherboards will support most of the CPU's. anyhow if you can give me the CPU model i can recommend some intel motherboards.
Posted on May 26, 2009
Anonymous
  • 80 Answers
SOURCE: i have intel 845gvsr motherboard so iwant to buy a new intel processor which is compatible
Although not quite what you need, but you can find a comprehensive list of the type of processors that your board support from the link below:
http://support.intel.com/support/motherboards/desktop/d845gvsr/sb/CS-026968.htm
Some further recommendations, the board is pretty old as it seems to fit Pentium 4 chips only. You may want to look at buying boards which suits a dual core at least.
Posted on May 29, 2009
rustysheriff
Tony Groves
  • 344 Answers
SOURCE: I have an ECS P4M800-M7 motherboard using Celeron
Intel Pentium 4, Celeron D and Pentium D processor FSB 800/533 MHz Support Hyper-Threading Technology Also says Dual Core support See here for information:- http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
Posted on Jun 13, 2009
I have intel pentium 4 3.0 Ghz processor kindly tell me which motherboard is available for this processor
Dear Sandeep,
845 series and 945 series motherboard are compatible with LGA 775 socket.
Hope this help:-)
Oct 31, 2012 | Intel Computers & Internet
Which tv tuner cards supports Intel Pentium Dual-Core E2160, 1.80 GHz processor ?
Usually a tv card is a peripheral that is determined to be compatible with a motherboard could you please tell me what motherboard you have?
Feb 28, 2012 | Computers & Internet
What is the processors that can be compatible for Intel motherboard
Confirm your motherboard's compatibility with the Intel CPU you want to install. Motherboards typically only support one type of CPU slot, so purchase an Intel processor that is compatible with that slot.
Ensuring your processor and motherboard are compatible is vital when choosing parts to build your own computer system. If they are both the same socket type, they will most likely work together.
Brands
There are a plethora of motherboard manufacturers, but only two main processor manufacturers: AMD and Intel.
Every motherboard, regardless of manufacturer, has a socket that will accept a processor.
Intel
Common Intel socket types include LGA775, LGA1156 and LGA1366. Older models include PGA370, PGA423 and Socket 479.
Your motherboard and processor will be generally compatible if their socket types match. ...
Intel Core 2 Quad Q9650 Processor Compatible Motherboards
Hope this will help you and please don't forget to rate me. Thanks for using FixYa
Aug 02, 2011 | Intel Motherboard
Is assus p4s533 campatible with a 3.2 GHz processer with 800 MHz FSB?
No it is only compatable 533 mhz front side bus processors not 800 mhz sorry fastest processor has to be 5333mhz fsb
Aug 02, 2009 | ASUS P4S533 Motherboard
I have intel 845gvsr motherboard so iwant to buy a new intel processor which is compatible
it support intel 478 pin processor 1.8 ghz 400 bus up to 2.4 ghz 533 BUS
May 29, 2009 | Intel D845GVSR Motherboard
May 26, 2009 | Intel Motherboard
Looking for a compatible processor for this mobo
It is impossible to fry a motherboard by using the wrong processor, the board simply won't post. You can use a chart at the ECS website, your motherboard is a Socket A type. Looks like the fastest processor that they have tested is a Athlon XP 3000+.
Apr 04, 2009 | EliteGroup 741GX-M Motherboard
Compatability
Check Intels website, when you find your processor check the x64 bit mode should say: Yes or NO. That will tell you. I don;t know your processor your using.
Mar 25, 2009 | EliteGroup ECS RS400-A (1.0) LGA775...
Processor
This are the compatible with this motherboard : Compatible Processors - Athlon, Duron, Athlon XP , Processor Socket - Socket A , Chipset Type - NVidia nForce2 400 , Max Bus Speed - 400 MHz .
This is the complete specs for this motherboard , check this link http://www.shopping.com/xPF-Asustek-A7N8X-X-Socket-A-LAN-nVIDIA-Audio
Don't forget to rate the solution FIXYA thank you.......
Oct 18, 2008 | ASUS A7V8X Motherboard
VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard Logo
82 people viewed this question
Top VIA Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Atiq
ChinthakaJ
ChinthakaJ
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
