Question about Microsoft Internet Explorer 8
My p.c switched off due to power failier. since then I cannot open explorer
Posted by marston_joe on
Nicholas Enyika
  • 506 Answers
Download Internet Explorer 8 (IE8) from the link and copy it to your system and run it again. You may uninstall the privious IE8
Posted on Mar 02, 2011
Shankar R
  • 206 Answers
Ok I suggest that you download and install the Internet Explorer 8 from the below link this will replace the corrupted Internet Explorer in the computer and re-installs the Internet Explorer 8.
http://www.microsoft.com/windows/internet-explorer/worldwide-sites.aspx
OR follow these steps to turn OFF and ON for the Internet Explorer in Windows Features to re-install the Internet Explorer.
Follow the steps from the below link:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C455429
On lcd fault DCbus failier
This might be due to the fact that the batteries are bad or you blew a fuse and the charger can no longer see the DC.
Sep 09, 2011 | MGE Comet Ex Rt 5kva 3:1 Ups + Mise En...
My windows dont go up or down . I replaced driver door master switch & fuse . sometimes I reclose dr.door it worked . what would make all windows not to work ?
it sounds like you need to check power supply to the switch cluster as connection may be interupted. you can also locate the power supply and run a jumper wire to switch from another positive source and then try operating window switch. you must also have a ground wire to complete the circuit. As you open and close the door you will notice a rubber casing that goes to the door and the truck pillar which houses the wiring to and from the door to the fuse cluster. Alot of times due to the movement of the drivers door (open/closing) the wiring has the possibility of fraying and become weak which result in lose connection
Dec 31, 2010 | 1998 Ford Explorer
ABS failier on r1150rt.I want to bypass and fit
when the ABS fails you do have an ordinary brake system.
Mar 30, 2010 | 2002 BMW R 1150 RT (ABS)
2005 silverado heater fan not working
unplug the blower motor and test it for power and ground, find out which isnt working, if there is a failier at the socket you may have a bad blower speed control. If that socket passes you testes then it should be your blower motor.
Apr 30, 2009 | 1999 Chevrolet Silverado 1500
My cooper 9534ds just melted and smoked inside my wall.
IIs this a 3 or 4 wire dimmer switch and red is feeding the fan with power? off hand It sounds like a failier inside the dimmer. if there was a short inside the fan it should have smoked at the fan or tripped the breaker. sounds like a hot spot in the dimmer.
Apr 26, 2009 | Cooper Industries Cooper Wiring 9534DS...
Rt rear turn & brake lights inop
Due to poor design on Fords part. When you use the tilt often, the wires inside due not have enough relief. They are to tight. My 02 sport track had same problem. Wire actually broke off inside the steering column. Take off the lower then upper plastic around column. You probably have broken or loose wires
Feb 03, 2009 | 2001 Ford Explorer Sport
Power failier upgradeing router
You may be able to get into the back of the router and use a paper clip to re-set it to factory. Look for the tiny hole.
Jan 24, 2009 | Computers & Internet
Power failier
beleive it or not set the clock,I work at an apartment complex and the cleaner always unplugs my stoves to clean behind ,everytime I plug back in PF,Just set the clock hours and minutes,Its just telling you you lost power incase you had something cooking in the oven,you wont think that your oven is broken,and also so it doesnt start automatically by it self please rate this solution thanks
Jul 13, 2008 | Whirlpool GS460 Gas Kitchen Range
Open Questions:
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; nsapshr 10.0.3) Timestamp: Mon, 7 Jul 2014 20:45:22 UTC Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js
Jul 07, 2014 | Microsoft Internet Explorer 8
See all Microsoft Internet Explorer 8 Questions
Microsoft Internet Explorer 8 Logo
136 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
