Question about Fisher and Paykel DishDrawer DS605FDSM Stainless Steel 23 in Builtin Dishwasher
SOURCE: U2 fault code?
The last two faults are logged into EE memory.
The other U (user) faults have been removed. The old U2 fault, which was the tub forced open during a cycle, has
been removed completely. Instead if the tub is forced open the product simply pauses as if someone had pressed
the start/pause button. The old U3 fault, which indicated a failure to drain i.e. water left in the tub, will not show up a
fault and the DishDrawer will continue through the cycle
Posted on Jan 22, 2008
SOURCE: water not draining from drawer
Could be the little non return valve mounted underneath the top drawer. Lie down on the floor under the top drawer, remove the main plastic pannel covering the bottom to expose the black drainage hose (you may need to cut away a cable tie). Remove the drainage hose from bottom of the drawer - at the start of the drainage hose there will be a small rubber type flap - if it looks broken or worn out, it will need replacing - call F & P for a replacement, approx $5 + postage for a pair (one for the top drawer and one for the bottom)
Hope this helps
Posted on Feb 13, 2008
SOURCE: dish drawer DD601v2
thats tub home sensor switch, mounts to rear right of cabinet and senses drawer closing along with little black box with red switch should also have a little metal actuator( this is what usually breaks off switch), each drawer uses their own. unistall from cabinet and theres an access panel strictly for replacing theses switches
Posted on Feb 23, 2008
SOURCE: bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
Posted on Nov 25, 2008
SOURCE: Dishdrawer DD601 v2 Error F1 on the bottom draw.
Below is the link to the service manual
http://www.scribd.com/doc/6462163/DD601V2-Manual
This will be able to explain the problems better that I can in the tiny space I get to write in.
Mat
Please rate me
Posted on Sep 24, 2009
To begin the test program, press both the SCRUB WASH and DELICATE/ECONO wash program buttons at the same time
as you turn the unit on by pressing the ON/OFF button. Initially, the control unit version number will appear in the display
(e.g./ 20 = version 20, 21 = version 21, etc.).
When the wash program buttons are released, the LED's above them will begin flashing. To end the test program or test cycle, press the ON/OFF button.
To check the wash program LED, press its corresponding button.
To check the Cycle Countdown display, Refill Rinse Agent LED and REGULAR WASH button LED, press the REGULAR WASH button (press the DELAY START button to test the
Cycle Countdown display alone).
The Cycle Countdown display should show "88" when the DELAY START button is pressed and "8h" when the REGULAR WASH button is pressed.
To start the test cycle, press both the SCRUB WASH and DELICATE/ECONO buttons a second time.
When the test cycle has completed, the Cycle Countdown display will indicate a fault using the codes below. If a combination of faults exists, the code numbers will be added together, (e.g./ 6 = faults 2 + 4).
0 = No faults
1 = Aqua Sensor ("Sensotronic") fault
2 = Heating fault
4 = Filling fault
8 = NTC (temperature sensor) fault
email me at [email protected] and I can send you via a "pdf" of the diagnostic/repair manual for your specific Bosch...provided it is indeed a SHU5316 unit.
I`ll watch for your reply. Good luck.
Regards,
Macmarkus :)
