Question about Refrigerators
I have a whirlpool 363L WRN38RWG6, the problem i am having is that the fridge leaks water from the vent inside the door on top of the fridge section, then the fridge freezes any thing put to the back of fridge & a lot of the water that leaks in turns to ice. Freezer works fine, i have also turned fridge down lower but still get the freezing & leaking to??
  • 35 Answers
I could not find the model but i assume it is a side by side.The model # should be located in the fridge side on the upper right hand corner on the fridge wall.On the freezer side in the back there is a cover with vents covering the evaporator coils. Remove the shelves,the cover to expose the evaporator.If the evaporator is all iced up your defrost themostat may not be working.The defost thermostat is located on top of the coils,it is a little round unit with 2 wires going to it.To check you can uplug it and put a jumper wire in the plug in to see if the defroster starts up.Make sure the fan is also working.Also check the drain (little round hole in the bottem of the drain pan) below the coils.Just poor a little water down it.If it is pluged you can use a small round tube and push it through the drain.Hope this helps,if so give us a 4 thumbs up. THANKS
Posted on Mar 02, 2011
6ya staff
SOURCE:
Water is dripping from a vent inside the top of the fridge section of the refrigerator. Model is a whirlpool wrx42rwh6
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 29, 2010 | Whirlpool Refrigerators
Water leaks inside . top shelves of ref section. Every day I sop up water from top shelves. Drain tube frozen?? How do I fix it?
if unit is a whirlpool, a kit is required to alleviate issue..you can turn fridge off and defrost it for 24 -hrs w/doors open...that should eliminate frozen drain problem
Mar 10, 2010 | Refrigerators
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Water leaks from vents in fridge
This could be your heater has malfuncutioned and what is happening is that when you turn it on the freezer is trying to get cold and frost and the heater is staying on and letting things melt very fast and causing a water problem
May 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool REfrigerator Freez WRN38RWG6 How do you stop water
Turn Fridge off,leave open for 24 hrs,then shut doors and start.The defrosted water had frozen up high and the fridge then leaks
Mar 01, 2009 | Refrigerators
Ice & water dripping in refrigerator
Seems that you now have to little gas in the fridge.Somewhere on your apparatus there should be a factory tag where it should be info on amount of gas, prod date etc and also which type of gas to fill.
Other thing as fan not running properly,door gaskets leaking can lead to Ice build up.
High humidity and water all over inside fridge.Gas filling procedure.Make vacum(vacumpump)Fill in correct weight (grams or oz)of gas.Anyhow when you must fill gas there is usually a leak in your system and to find that i use liquid nitrogen.For this serviceman is the best option.
Regards. jan(Norway)
Feb 12, 2009 | Whirlpool GD2SHGX Refrigerator
Fridge leaks water on the inside, is not condensation
Hi!!! Your drain line is plugg, also there might be some dirt plugged so remove the evaporator panel are clean the drain line..deb5a30.jpg
Jan 04, 2009 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool WRN38RWG6 fridge freezer. Fridge won't cool
...try taking the fridge to Thredbo or some other location that gets subzero temperatures and then leaving the door open 'til the interior cools down. Canberra this time of year could work. You could also try just filling it with some frozen water. Most service stations have it in plentiful supply. Best solution for a non-hottness deficiency.
Dec 07, 2008 | Whirlpool Refrigerators
Refrigerators Logo
296 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
