Panasonic SC-HT730 System Logo
Question about Panasonic SC-HT730 System
Hola necesito desbloquear el panasonic modelo sa-ht730
Posted by djjarro on
  • djjarro Mar 02, 2011
    hola necesito la informacion x favor
3 Related Answers
Anonymous
  • 1197 Answers
SOURCE: Im looking for the manual for the sa-ht730 please
hi
kindly download the manual from the below link
http://service.us.panasonic.com/OPERMANPDF/SAHT730.PDF
rating the service very helpful will be appreciated...
Posted on Aug 09, 2009
Steve
  • 3290 Answers
SOURCE: Panasonic SC-HT730 Green picture when showing DVD's
The DVD player of this system will output to a TV on either composite (Yellow jack), component (RGB jacks) and S-Video (a small round jack that looks like a mouse or keyboard connector) jack. Since the tint is off, I would guess that you're using the more desirable component or even the S-video jack. Try removing & re-seating the plugs into the jacks at the DVD and at the TV; then check the picture color. If it still is wrong, try using a different cable type - use a standard video cable between the yellow jacks on both the TV and DVD. You may need to set the TV input to reflect the use of the new jack - and possibly set the DVD to 480i or Interlaced if you used the Progressive Scan or 480P output when using component RGB video cables (Red, Green & Blue). Check for correct color.
Chances are the connection got dirty and caused the color issue - or less likely, the cable or even less likely - the DVD output has failed.
Posted on Mar 26, 2010
Anonymous
  • 8546 Answers
SOURCE: SA-HT730 need help with the above problem it just
Are you trying to reset the password for Ratings or re-initialize the unit to all factory defaults?
http://www.retrevo.com/support/Panasonic-SC-HT730-Home-Theater-Systems-manual/id/356ci961/t/2/
Page 27 shows one instance of INIT.
Re-initialize Setting
This returns all values in the Setup menus to the default settings.
≥Yes: The password screen is shown if "Ratings" (??? page 26) is set. Please enter the same password. After "INIT" on the display disappears, turn the unit off and on again.
≥No
Page 36 shows how to reset everything.
You have forgotten your ratings password. Reset all the settings to Factory Preset.
While stopped and "DVD/CD" is the source, press and hold ['Square Icon' button for STOP] on the main unit and [S10] on the remote control until "Initialized" disappears from the television. Turn the unit off and on again. All settings will return to the default values.
Posted on Jan 14, 2011
4helpful
7answers
1helpful
Codigo para desbloquear el motorola rockr z6m
hola hay muchas maneras para desbloquear el
m?viles que pueden utilizar el software, cable, c?digos, etc ... entre
los c?digos son los mejores. Hoy en d?a hay muchos sitios en l?nea que proporcionan encontrado
los c?digos para desbloquear el mobile.you pueden obtener los c?digos de aqu? classicunlocking aqu? piden
los siguientes datos que son modelo de m?vil, el pa?s y la red que bloquea el imei m?vil,
n?mero del m?vil. finalmente se le enviar? los c?digos para desbloquear el m?vil.
Desbloquear celular
hola puede utilizar c?digos para desbloquear el m?vil. puedes obtener los c?digos de este sitio mobileunlocksolutions ser? ?til para m?, si usted ha mencionado el modelo de m?vil, el pa?s y la red a la que su m?vil es locked.here en este sitio se proporcionan los c?digos para todos los modelos de m?viles, junto con instrucciones sobre c?mo introducir los c?digos en tu m?vil.
2answers
Hola, mi sanyo no funciona no se ven los canales digitales apesar de estar conecta al TV por cable
¡Hola
¿Cu?l es el n?mero de modelo ofyour Sanyo TV? Sin el n?mero de modelo, ¿c?mo puedo detectar sus especificaciones? S?plicas me env?an el n?mero de modelo de su televisor Sany por caja de comentarios FixYa, o volver a publicar su problema con todos estos dtails nuevo. Aceptar.
Necesito su codigo de desbloqueo
Puede obtener el código de desbloqueo para el Noki 5130 Express Music Mobile en el modelo de costes fiables aquí
http://www.wickedunlock.com/nokia-5130-xpress-music/rs11wp9/ y desbloquear móviles ..
Tengo un control universal NOBELSOUND NS-V3 y necesito un codigo
hola buenas noches tengo un problema y es que tengo un control universal nobelsoun ns-v3 pero no he podido encontrar el codigo de mi tv el cual es un panasonic y el modelo es CT-Z2151V ESPERO QUE ME PUEDAN AYUDAR GRACIAS
Necesito Saber el modelo de placa Toshiba L300-SP5807
Hola, Usted puede obtener las piezas de los siguientes sitio web. http://tinyurl.com/at8t9f Usted puede llamar a este número si se encuentra en los EE.UU.. 1-877-253-8898. Thanks Proton
Hola necesito el nombre del conrolador de graficos de un compaq presariopara xp
Depend de el modelo, son todos diferentes, de que modelo presari se trata?
si no sabe el modelo puede encuentrar las controladoras buscando en este sitio :
HP Support & Drivers
Top Panasonic Audio Players & Recorders Experts
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
