Question about HP Deskjet D4260 Printer
Print jobs hang, won't finish, locks up printer
  • Anonymous Mar 02, 2011
    I unistalled all the HP bloatware that cam with the "new updated" drivers, and left only the original drivers installed, rebooted, and it prints with no problem now. Not a queu isse, a driver issue. My system is Win 7 64 bit, BTW.
havingline line
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 149 Answers
You must check print Queue, where's the printer one by one give access to print out. On there have status Queue, if any status Like "Stop,problem,etc" you must delete this Queue.
Posted on Mar 02, 2011
Printer hangs
check touch screen job status. this particular user might not have the setting configured properly on his pc and affected all job queue due to paper size not avail in any drawer or bypass paper needed.
to release the rest of the job queue, just delete the job pn the touch screen. u can see the delete button on the touch screen when u press job status
Mar 20, 2014 | Toshiba e-studio 455 Copier
In Windows 7, items put in the print queue at home won't print when I get to the office.
I don't see how this can be done, because there are 2 different print queues in question. Not to mention the lag and buffer required by the printer. So when you disconnect communication the job hangs.
Besides the spooler at work my lie on a dedicated print server, especially if the printer is on a network and and not attached directly to you PC.
Feb 26, 2013 | Microsoft Windows 7 Professional for PC
On my home wireless network, my notebook computer's print jobs go to the correct printer but won't stop printing until it is canceled from the device manager. The PC that is on the network wor
sounds like the print job queue is overloading the wireless network, causing a hang on that side
big print jobs do that even on wired systems might consider adding more printer memory
May 26, 2012 | HP P2035n Laserjet Printer Monochrome
Only prints first job - can't delete from que
Please try this approach instead:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
I hope this information has been helpful.
Dec 20, 2011 | Lexmark X6170 All-In-One InkJet Printer
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
Jun 10, 2011 | Lexmark X2670 All-In-One Printer
Printing Problem in xp when i restarted the print spooler service print job is started
you need to cancel previous pending printing job or allow printer to finish it's by feeding paper on to it until it finish all the printing job.
Feb 04, 2011 | HP LaserJet 1020 Printer
Samsung slp 770 incomplrte session by time out
The Samsung CLP 770 produces an 'incomplete session by time out' if you switch off the computer originating the print in the middle of the print job (before the print is finished) OR if the network connection is lost between the computer originating the print and the CLP 770.
The printer may have printed the start of the print job but also recognises that it has not received the end of the print job information. It waits for a good while for the connection to be restored in an attempt to receive the rest of the print job - but if nothing comes then it times out.
The reason for this action is to prevent this situation effectively locking out any other computer on the network from printing while it 'waits' for the end of the print job.
Dec 28, 2010 | Samsung CLP-770ND Laser Printer
Not printing and nothing is paused or on the print list.
First of all you must let canceled print jobs finish deleting before sending new jobs, if the job is taking too long try restarting the computer with the printer on to clear the jobs this usually works if not then after restart open the printers folder and cancel all jobs here. let them finish deleting while the printer is still on (they must remain in communication during deleting jobs. Once all jobs are gone, remove the power brick from the printer for about a minute then reinsert and let the printer start up if it doesn't after a minute or so just turn it on once it finishes then try printing again.
Oct 14, 2008 | Dell 926 All-In-One InkJet Printer
Printer hangs up.
1. check the printer, make a copy
2. check connectivity, open device manager - USB Printing Support(under Universal Serial Bus Controllers) must be there - swap cable/port if it´s not
3. uninstall, reboot then re install printer driver
Jan 03, 2008 | Epson Stylus CX5800F All-In-One InkJet...
HP Deskjet D4260 Printer Logo
176 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
