The breaker goes in in series.
So, that means (for example) you remove the hot wire to the unit, from the positive battery power source, and hook this wire to one side of the breaker, then connect the other terminal to the positive battery power source.
This will stop current flow if anything over 40 amps happens on the line.
You actually can hook the breaker anywere along the circuit, but the closer to the power source, the better you are protected.
