Canon Printer Error Code B200 typically means that your printer head is gone. You don't have to think about this failure you can correct this error by reinstalling or reloading the printer engine. The printer driver can be compromised and patched by downloading the upgraded version of the printer driver.
Canon Printer Error B200 failure means Print Head is gone!
If you going to the purchasing of a new printer, I would recommend some troubleshooting
Replace all of the printer ink cartridges and reinstall it now.
Disable Print Head and clear up all contacts on the print head
Bear in mind that all the print head cleans it by flushing out all the ink under hot water.
Check and activate the printer driver since some of the cases have corrupted the printer driver and display B200 Error
Disconnecting wire connection and after a while, you can plug cable wire
Restart the printer
Again, this problem occurs, and then some technical solution is required. You should refer to the Canon Printer team of specialists. They're trying to fix your issue at a time
Check this blog -
