I have an ipod touch. Everything is working fine except the screen view is always zoomed in. It only shows the partial home screen, but I can move around to see everything, but it stays zoomed in. It just started happening. I tried restoring it, but the problem persisted.
You must have zoomed-in the screen accidentally. It's easy to zoom-out, just double-tap anywhere on the screen using 3 of your fingers (simultaneously) and everything will go back to normal.
And in case you want to zoom-in again, just do the same thing.
For more iPhone / iPod touch tips, click here.
Also visit my blog for app recommendations.
You must have zoomed-in the screen accidentally. To zoom-out, just double-tap anywhere on the screen using 3 of your fingers (simultaneously) and everything will go back to normal.
If you want to zoom-in, just do the same thing.
For more iPhone / iPod touch tips, click here. Also visit my blogfor app recommendations.
you can try and restore it. remember it will clear everything from your ipod but you can resync them later after restoration, to restore: make sure you have itunes running and have access to the internet.
hold down the power/sleep button and the home button at the same time, the ipod will go dark, once it goes dark release the power button while still holding down the home button, and itunes and a usb cable icon will show up.
you might have to do this several times before those icons show up since your screen does not even light up.
now connect the ipod to your computer and itunes should recognized the ipod and follow the instructions to restore your ipod. it will take some time but it worth the wait.
Press and hold the Home button for at least six seconds, until the application you were using quits.
If that doesn't work, turn off iPod touch and turn it on again. Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
If that doesn't work, reset iPod touch. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
If iPod touch continues to freeze or not respond after you reset it
Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all your data and media are removed from iPod touch.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
From Apple Website1. Restart your computer (yes, you have too) 2. plug in your ipod touch (it should have the usb cord and itunes picture on the screen) 3. open itunes. 4. itunes will recognize the ipod. just ignore the message, and then hold down the home and hold button (on the top) for about 10 seconds, and after you count to 10, release the top hold button, but still holding home. 5. itunes will pick up the ipod, and once it does, release home. 6. Now click restore, and everything should work fine. (if problem persists, try turning off firewall, and close all other programs)
Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
and you are sure the volume is all the way up? If the headphone jack thinks there is something in there the ipod touch will only play through the headphones. you can try to blow out any dust in there with a can of air and that might solve your problem.
