Question about Hitachi 36CX39B 36" TV
My 8yr old hitachi 36" tv keeps going in and out.
Posted by lori_010972 on
Anonymous
    Master:
  • 691 Answers
This is what is called the vertical IC, This is a flat ic on a heatsink and it could be label LA-______ something, I don't remember if it's 1601 location or what. also change out caps, like 100uf and 220uf, around this ic also loose connection are a problem with this too.
Posted on Mar 05, 2011
I have black line down right side of 42 inch hitachi lcd tv screen
You have a CCFL lamp that is failing in the panel, time for a new TV
Jan 22, 2018 | Hitachi Televison & Video
8yr old apex tv keeps shutting off
have short somewhere---most common area is power supply or convergence circuit if this old.
May 23, 2012 | Apex Digital Televison & Video
My tv screen shrunk in from the sides
Ok, you have a problem in the Horizontal output circuit--width etc.
Going to be a shop repair as most shops will not tackle this in the home--36 inch from the model indicated so expect repair to exceed 150 parts and labor.
If the border is not large on both sides the set also has a tech menu accessed with the remote--adjustments are there for centering and width--it will not fix a circuit problem.
May 03, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a old tv 36 inch panasonic ct-36d30 my tv
sound like yoke short problem. replace same yoke as possible . good luck!
Feb 15, 2010 | Panasonic CT-36D32 36" TV
Color ghosts out of allignment
This is a convergence problem that can be as simple as poor connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside the set where there are potentially dangerous high voltages even when unplugged, you can fix this yourself.
Let me know if you wish to attempt the repair and I will post additional details and instructions.
Dan
May 05, 2009 | Televison & Video
Spots on Hitachi 53SBX01BA
green tube has problem maybe bugs if your lucky and lens has to be removed. If your a novice at tv repair call a service center
Apr 29, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Picture shrinking
HI: Well that is a good indication you have a intermittent connection in the circuit board. Its time to take it to a repair shop. He will re-solder the poor connections. You should not need parts. Good Luck.
Mar 08, 2008 | Televison & Video
Hitachi 50" TV, no picture, blue light flashes
Replacing the board is much more expensive than repairing it, if the repairs can indeed be done...accordianman
Sep 16, 2007 | Hitachi 51F510 51" Rear Projection...
Hitachi 36CX39B 36" TV Logo
Top Hitachi Televison & Video Experts
Paul Bade
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
