Plantronics Explorer 240 Bluetooth Headset Logo
Posted on Mar 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to pair to the phone - Plantronics Explorer 240 Bluetooth Headset
  • Anonymous Mar 01, 2011
    What kind of phone do you have?
Jose Ma DM.
Level 3:
  • Master 540 Answers
  • Posted on Mar 01, 2011
Jose Ma DM.
Master
Level 3:
Answers
540
Questions
0
Helped
177123
Points
1776
Please follow this procedure:
  1. In the headset press and hold the call control botton until the indicator turns red and then turns off, press and hold the call control botton until the indicator light continues to flash red and blue, the headset is now in pairng mode.
  2. In your phone, go to bluetooth conectivity and select scan for devices, select de Plantronics bluetooth headset from the list, enter 0000 for the passkey and OK/accept to bond them.
Anonymous
Level 2:
Novelist:
  • Expert 149 Answers
Anonymous
Expert
Level 2:
Novelist:
Answers
149
Questions
0
Helped
73182
Points
482
You can use the link below to know how to pair Plantronics Explorer 240 Bluetooth Headset...
plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=17639&p_created=1272318021
Hope it helped.
Anonymous
Level 1:
New Friend:
  • Contributor 31 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
3848
Points
92
On your phone, under settings, there should be a bluetooth option (if your phone is bluetooth compatible). Turn on bluetooth on your phone, then turn on your head set. Usually there is a connect button on the headset, hold that down. On your phone you should see the headset as an option to connect to.
Anonymous
Level 2:
  • Expert 242 Answers
Anonymous
Expert
Level 2:
Answers
242
Questions
0
Helped
75989
Points
807
Cannot pair samsung alias phone to motorola bluetooth
Hi,it's very easy to pair.
First get one of the phones blue tooth on, and pair with the other phone .
When pairing,it will ask you for password key, you can use any number of your choice, but it has to be a four digit number.(Any four digit number) eg 1234,1111,0000 etc.
Ones you type in the code you want to use for pairing, it wlll ask you on the other phone you are trying to pair to type in that the same code and your done with pairing you, Ones the other phone recognizing the phone you paired it with you can now send data to each other.
If it does not pair immediately, restart the phone and try again.
Good luck.
1helpful
How do I pair bluetooth from one phone to a new phone? Removing bluethooth from my old phone to another phone.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Can not transfer songs from my old phone to my new phone via blue tooth the both phone have connected but when i try to send information it comes up not connected
Hi, you will need pair both phones together before you can be able to send .
Take care.
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
3helpful
Pairing bluetooth to my phone
  • general instructions for no specific phone and device to pair
    • turn on both devices (phone and other device)
    • on the phone search for a bluetooth devices(that is on)
    • if the other device is asking for a password, enter a known password to success the pairing
    • or else it will pair automatically for a non password pairing
26helpful
2answers
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 • Cell Phones
2answers
I can't connect Verizon Gleam SCH-U700 to Parrot CK3100
This solution came from Parrot Tech Support and it worked for me:
We were able to get the two to pair using the following steps:
The phone will stay saying pairing, then the parrot will say pairing successful, pull the battery on the phone, when you turn it back on, the phone will display PARROT CK3100 WANTS TO PAIR, ACCEPT? Say YES.
Mar 11, 2008 • Cell Phones
1helpful
4answers
Paired with old phone, can't pair with new phone.
have ya phone ready to almost pair. Then on the 850 ear piece press the call button until lit and then open boom up and press the phone pairing ok button and the 850 should work. waaala!
See how easy that was.
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
