We think there could be a bearing going it is very noisy and the drum seems lose.
  • hicrip007 Mar 01, 2011
    is the washer front load or top load
    Genius:
  • 1,041 Answers
It is more likely the bracket that holds the drum to the spindle - oftewn called a 'spider'. This has three or four 'legs' - if you look at the back of the drum you will see the indentations in a star pattern. One or more 'legs' has probably broken and so the drum is no longer able to spin centrally. The spider can be replaced by a washing machine repair engineer. Do not continue to use the machine unitl it is repaired because a loose drum will cause additional damage (mine wore through the heating element).
Posted on Mar 01, 2011
Servis 1200 very noisy in spin modes. Inner drum seems to be very loose and wobbly. Noise sounds like a roller with flat spots running on the drum, or a very bad (failed) bearing. Machine is 12 years old,...
the bearings have gone, if the drum can be split, remove complete drum and replace bearings, if you dont think its something you can do, dont attempt it, but to be honest, its realitivly easy
Sep 09, 2013 | Washing Machines
Hotpoint condenser dryer noisy
hi if you push inside top at back of drum u will feel if lift if so yes u need bearing just ask for rear bearing for your model more than likely teardrop bearing
Nov 14, 2012 | Hotpoint Dryers
When machine went into spin it was very noisey and the metal tub has rubbed agaisnt the plastic inside and caused A bit of damage were it rubbed but the rubber seal was not touched I have taken the back...
It sounds like the bearings have collapsed..You may have noticed a noisy spin cycle prior to loosness in the inner drum...This is a big job. Get quotes...Good luck...Nomess
May 20, 2010 | Washing Machines
Noisy Washing machine drum
To replace bearings is quite a job. iyf your good at diy i rate this as a 9/10 ....A bearing kit is available from makers and instructions.
Apr 03, 2010 | Ariston Technologies AWD120WH Ariston
Machine noiser than it use to be when tub spins
From the front of the washer, spin drum by hand, and if it feels rough or is noisy, then the main drum bearings are probably worn.
Another possibility is the motor bearings noisy, or a worn armature.
If the noise is gradually getting worse, then I think it is safe to say it is the main bearings.
Jan 26, 2010 | Hotpoint WMA40 Front Load Washer
When my zanussi aquacycle 1200xc is on the fast spin cycle the spinning drum seems to be getting noisier of late.
Probably the main bearings are going, spin the drum by hand, there should be little or no noise at all, if it feels rough, or noisy, then bearings are failing.
Please rate my solution.
Thanks.
Oct 10, 2009 | Zanussi F1245W Front Load Washer
Noisy Servis M9503S
Hi.
Remve the belt, and turn the drum by hand, if it sounds rough or is noisy, then yes the main drum bearings have failed.
It is a DIY job , but can be expensive, probably cheaper to buy new washer if it is more than 3 or 4 years old.
Nov 22, 2008 | Hoover AAA140 Front Load Washer
Rear wheel bearing
first you might want to go on you tube and look for a video on it.but if they do not have it then go to a micanic to get some tips. (P.S it is not a easy job.)
Sep 21, 2008 | 1994 Volkswagen Jetta
Indesit widl 126-problem with the drum,moving back and forth to much and noisy.
It would seem that the bearings go on this model, which causes the inner drum to knock and bang against the outer during spin. If you continue to use the machine without replacing both sets of bearings, it will cause irreparable damage and the machine will need to be replaced.
Apr 27, 2008 | Indesit Washing Machines
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
