Question about Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack
Can I charch my new ryobi batery lithium whith the old charch
Posted by bandidoychiq on
Ashraf Sharif
    New Friend:
NO THE OLD CHARGER FOR THE BLUE ONE+ TOOLS WILL ONLY CHARGE NICD BATTERIES. HOWEVER THE INTELLIPORT DUAL CHEMISTRY CHARGER WILL CHARGE BOTH NICD AND LION BATTERIES. ALL BATTERIES ARE COMPATIBLE WITH ALL ONE+ TOOLS
Posted on Mar 16, 2015
Sparky42
    New Friend:
  • 11 Answers
If it fits into the charger you can charge it. Much like the difference between 110V and 220V outlets, they design chargers and batteries to only work with physical matches.
Posted on Mar 01, 2011
Can I use my old Ryobi charger (#1423701) to charge my new Ryobi LITHIUM battery?
If the old charger has a deep-uncharge-protection contact and was also made for Li-ION ther is in any case a marketing technical design by a notch to protect the battery to place on the charger if this cells are not correct.
(this answer applies to all brands with a quality mark)
Apr 12, 2016 | Ryobi Drills
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
Feb 18, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
What Ryobi batteries p103 or p104 will a battery charger that came with my p100 batteries charge? Or will the charger work with these batteries?
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Jan 11, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
When using the lithium bateries in the new 1/2 drive impact under any stress the drill loses all power and the battery status goes from green to red. remove the battery and put it back in and its back to...
the batter cells are weak and wont hold a full charge, replace with a new battery, also check that there is nothing in the way of the contacts such as foreign debris inside the battery cavity of the impact.
Dec 31, 2010 | Ryobi Drills
Can you charge ryobi lithium batteries in a regular ryobi charger?
NO! Never charge lithium batteries in a charger designed for nickle based batteries like the NiHi your old charger was meant for. Ryobi did design the new Lithium charger to be backwards compatible so you can charge your older 18V NiHi batteries in the Lithium 18V charger.
Also note, NEVER miss-match the voltage, for example, make sure you are not trying to charge 12V batteries in an 18V charger unless the manufacturer has specifically stated that the charger is capable of multiple voltages.
Dec 25, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
New Ryobi 18v lithium battery goes dead after a couple of seconds. Is there any solution other than returning it?
No, just return it, for the money they should give you one that works. It is common to get a defective Ryobi 18v lithium battery. I've had 2 out of 7 purchased that wouldn't hold a charge. But when you get a good one they work awesome!
Jan 24, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Can I use this Ryobi Charger?
If you're speaking of the new green lithium battery charger working with the older yellow and black batteries, yes you can. You can't use the OLD charger to charger the New lithium batteries.
Jan 26, 2009 | Hand Tools
Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
321 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Marvin
Marvin
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
