Question about HP 1730 LCD Monitor
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
    New Friend:
  • 39 Answers
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Posted on Mar 01, 2011
    Novelist:
  • 147 Answers
Follow this link: http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Basically you have Four options.
Fix One: Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two: Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three: Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four: The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
Good luck and thanks for using FixYa.
    Scholar:
  • 138 Answers
Instructions
  1. 1My HP 1730 monitor is - fix-lockout-display-computer-monitor-1.1-120x120.jpg The OSD Lock Out Message
  2. 2
  3. 3
  4. 4
  5. 5 The OSD Settings Menu
I can't unlock my osd screen, tried everything
While holding it, turn the monitor on. Once the monitor is on for a few seconds, let go of the "left" button. Your OSD should be unlocked. This is how it works to lock press and hold the MENU button while the monitor is off and then press power button to turn themonitor on.
How to unlock the OSD of an AOC monitor - Quora
https://www.quora.com/How-do-you-unlock-the-OSD-of-an-AOC-monitor Feedback
About this result
How to unlock OSD my HPx20 LED wide screen monitor?.. - HP Support ...
https://h30434.www3.hp.com/...Lockup/...unlock-OSD-my...screen-monitor/.../74766... Jul 4, 2011 - Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD. "Power button is locked" message - HP Monitor 27es
Aug. 31, 2017
OSD Lockout on HP Pavilion 27xi - how to unlock?
Apr. 5, 2017
HP monitor Main Menu / OSD Lockout cycle continuously
Jul. 9, 2009
More results from h30434.www3.hp.com
HP LCD and LED Monitors - OSD Lockout Message Appears on the ...
https://support.hp.com/ca-en/document/c01932183 What to do when an OSD Lock out message opens. ... OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
display - How do I lock and unlock the OSD of a "AOC monitor 21 ...
https://superuser.com/.../how-do-i-lock-and-unlock-the-osd-of-a-aoc-monitor-21 Aug 29, 2009 - OSD Lock Function: To lock the OSD-First make the Monitor off by pressing power button and then hold the Left button for 5 seconds and simultaneously hit the power button with the left button and the osd is Locked. If your AOC e2343F is locked then just power off your screen and hold power and menu buttons together.
can unlock my osd screen Google Search
Jun 12, 2018 | Cars & Trucks
Hi! I have a problem with my montior and I hope you can help me! I have a LG monitor L1918s. on monitor it appears all the time "ocd locked" and after 5 secondes it changes into "ocd...
ocd unlocked and lock definition: This function allows you to lock the current control settings, so that they cannot be inadvertently changed.
This is a method to unlock it: Press and hold "Menu" button for several seconds until the monitor show message "OSD Unlocked" and then you can use the monitor's button again. There's a chance that "OSD Locked" message will disappear from your monitor but don't stop until "OSD Unlocked" is showed. If it is being shown automatically you must have fiddled with the buttons to much and set a delay.
If I have not solved your problem please reply and explain to me in more detail what your problem is.
PCHELPSTER007 from youtube
Jun 25, 2011 | Computers & Internet
My monitor is of AOC " e2043Fsk " . When I try
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jan 03, 2011 | ASUS Computers & Internet
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
plz do rate the solution if helped
Nov 22, 2010 | HP L1506 15" LCD Monitor
Starting the PC have got error on HP 1730 Monitor error message, OSD Lock out. Can you please tell me how to solve this issue?
How to Unlock an "OSD Lockout" Problem
smilie-tag.png monitor, osd lockout folder-category.pngPosted in Fixes ' Comments (32)
osdlockout.jpg This has most likely annoyed many of you at some point. You turn on your monitor one day and see a jeering message telling you something about an "OSD Lockout". It doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While I've only seen this error on HP monitors I know that others have encountered it on other brands as well. The fixes I provide should work on those monitors too. (Note: OSD stands for On Screen Display.)
If you know of any other fixes feel free to contact me. Good luck!
Having other problems with your computer? Simply scan your computer for free to identify problem areas.
Techbelkin please rate me
Nov 02, 2010 | HP 1730 LCD Monitor
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
My hp 1740 monitor is displaying osd lockout and menu back ond forth and i cant get rid of it
  1. Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
  2. Step 2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
  3. Step 3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
  4. Step 4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
  5. Step 5 fix-lockout-display-computer-monitor-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/or/7q/fix-lockout-display-computer-monitor-1.5-800X800.jpg'); }); The OSD Settings Menu Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Apr 15, 2010 | HP L1740 17" LCD Monitor
How to unlock OSD lockout in HP L1940T Monitor
How to unlock HP 1940 LCD monitor?? i try with holding menu button and power also..but didnt show me unlock...i hold like 1min even more...and its keep to blink OSD lock...and Main Menu on my screen.Can u tell what i need to do Thank you
Jan 20, 2010 | HP L1940T 19" LCD Monitor
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
Problem in TFT
  • If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
  • If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jun 09, 2008 | LG L1915S 19" LCD Monitor
HP 1730 LCD Monitor Logo
2,086 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
