Question about Fuji FinePix S5000 Digital Camera
The screen on my fujifilm s5000 all of a sudden went white. What I have read the ccd went bad, can that be fixed. I found direction to clean it or check it, but the link has been broken.
Posted by brian6591 on
Anonymous
    Sergeant:
  • 269 Answers
If it can fixed, Fujifilm themselves will have to fix it.
Posted on Mar 02, 2011
My fujifilm fine pix s5000 digital camera is having some problems. When I turn it on the screen is white but I can see icons. I'm not sure if it's related to the camera or if I just need a new card?
the video from the ccd is not making it to the lcd
does it shoot pictures if so then you have a good point n shoot blind camera
its not worth fixing .
May 09, 2015 | FUJIFILM Cameras
My view screen is white but I am able to view my pictures on my memory card
Most likely a dead CCD (imager) unit. Happens to these cameras. Usually they are supplied with the lens and are expensive if ordered from Fujifilm - could be about $200-300. I wouldn't recommend using used parts because they could break down again sooner or later. I suggest you buy a new camera.
I have worked for Fujifilm.
Tom
Mar 05, 2011 | Fuji FinePix S5000 Digital Camera
Won't take pictures!!
CCD FAILURE !
CALL Fujifilm they will do it FREE it is a known problem in thousands of camera i got my S5000 with same problem repaired FREE from FUJI just call them
BAD CCD
RATE ME WELL !
May 31, 2009 | Fuji FinePix S5000 Digital Camera
Fuji Fine Pix s5000-Horizontal lines with purple coloring mixed
not a software issue it is
CCD FAILURE !
BAD CCD
RATE ME WELL !
May 27, 2009 | Fuji FinePix S5000 Digital Camera
HI All of a sudden, there is lets say no more image on the display or the image is purple and full of weird lines. No image at all and when I click to take a picture everything works out well: the flash...
BUT NOW U HAVE FOUND SOLUTION
CCD FAILURE !
but u will get it repaired Free of Charge as Fuji has taken notice as all manufac and i got my S5000 repaired Free from Fuji just call them tell them about BAD CCD it is a known manufac fault in thousands of cameras just call them quick
www.fujifilm.com
see this thousands suffer from this
http://www.imaging-resource.com/badccds.html
May 08, 2009 | Fuji FinePix S5000 Digital Camera
I have a fujifilm finepix S5000 when camera is turned on it just shows a white screen. Cant take pictures, movies, nuffin works. Can u help, please.
if u see white screen and lcd show info and signs and pictures also turn out to be blank when u see them on pc
CCD Failure has occured !
dont worry i have the same problem with my S5000 i contacted fuji and they repaired it free of charge bcoz it is a known problem in thousands of cameras of different brands just call them in ur area and they will do it free of charge
see this
for support in usa or select different region www.fujifilm.com
http://www.fujifilmusa.com/support/ServiceSupportContact.do
Apr 09, 2009 | Fuji FinePix S5100 Digital Camera
Change from black and white to color
There is a little blue button next to the LCD button, directly above the display screen. There are alot of controls when you press, like color, B&W, shutter speed, etc. Thanks
Sep 29, 2008 | Fuji FinePix S5000 Digital Camera
Fuji Finepix S5000 ccd sensor
Send it to the Fujifilm camera repair center. The S5000 has a known issue with bad CCD sensors... Unless you want to do it yourself.
Jun 26, 2008 | Fuji FinePix S5000 Digital Camera
White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Nov 12, 2006 | Fuji FinePix S5000 Digital Camera
White Screen
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager( they are still doing it). check it out.
Sep 25, 2006 | Fuji FinePix S5000 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Rob Hill
Rob Hill
Are you a Fuji Camera Expert? Answer questions, earn points and help others
