Question about HP Deskjet 3845 InkJet Printer
My hp deskjet says there is a paper jam when there is none and will not print
Posted by patriciac187 on
Allen Paredes
    New Friend:
If you cleared all the papers in the printer and it says again "paperjam" call for technical assistant or troubleshoot it. Hope i helped :)
Posted on Jan 17, 2015
Eseoghene Daniel Williams
  • 428 Answers
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Posted on Mar 02, 2011
5 Related Answers
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: hp deskjet f380 paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 24, 2009
Anonymous
  • 3 Answers
SOURCE: HP Deskjet D 4160 Printer quit working after paper jam.
Replace both cartridges, power down and try again. The blinking light stopped and now I'm able to bring. Had gone through powering down four times before doing this.
Posted on Jun 16, 2009
Anonymous
  • 72 Answers
SOURCE: HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Posted on Jul 22, 2009
Anonymous
  • 40 Answers
SOURCE: HP Deskjet F4185 series says a paper jam error
did your orinter experience a paper jam before?
try to clean inside again maybe there are small paper left inside
i hope this can help
Posted on Mar 29, 2010
Anonymous
SOURCE: paper jam in hp deskjet 5900 series. how do i correct?
hp 5900 printing report after print
Posted on Apr 20, 2009
Hp deskjet 3845 printer will not print and it is no paper jammed, it is installed properly
it sounds like your printer is not connected to the pc or laptop,check the USB cable properly.another problem is paper jam or which leads to qeueing of docs to be printed.
Mar 01, 2013 | HP Deskjet 3845 InkJet Printer
My printer HP Deskjet 1051 says there is a paper jam but no paper jam present
Use a flashlight to examine as much of the paper path as you can see. There may be a shred of paper left over from an earlier jam. There might be some foreign object such as a paper clip stuck inside.
Sep 14, 2012 | HP Deskjet 1051 All-in-One Printer
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
The printer keeps jamming when i try to print. The light keeps flashing and it says jammed paper but there is none.
Open the printer casing and clean the paper sensor and the tray . After that clean the rod with iso-propyle or petrol and remove all the dust from the board also.Your printer needs dusting only.Let me know when problem gets rectified.
Jun 25, 2009 | HP Deskjet 3745 Inkjet Color Printer
HP Deskjet 3550 keeps printing in pink
HP Deskjet 3550 MODEL NUMBER:VCVRA-0202
Feb 05, 2009 | HP DeskJet 3550 InkJet Printer
Printer will not print
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Jan 04, 2009 | HP DeskJet 3650 InkJet Printer
Hp deskjet 5150 paper jam
u have to need to do change the printer roller
Sep 01, 2008 | HP DeskJet 5150 InkJet Printer
HP Deskjet 3940 (Paper Jam)
I have a HP Deskjet 3940 printer. And similarly to this problem here I had a paper jam that would not clear, despite removing all the paper that was stuck in it, and following all 4 steps stated on the HP website. Such as taking the back cover off and blowing dust away and turning it off and on, etc.
None of these steps worked for me and consequently I couldnt get any new jobs to print - kept saying 'paper jam'. I was about to head down the shop to buy a new printer when i tried one last thing, which HAS fixed the problem!
I put in a large stack of paper onto the feeder. and then pushed it forcefully in and out repeatedly. To my amazement this has solved the paper jam. As a very last resort, might be worth trying this?
Jul 25, 2008 | HP DeskJet 3940 InkJet Photo Printer
HP Deskjet 3845 InkJet Printer Logo
1,887 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
