E1 ERRORE COMES IN M Y AC WHICH REASONS - Heating & Cooling
Posted by www_mahen236 on
jorgebermude
    Problem Solver:
  • 5 Answers
Owners of Sharp air conditioner models
AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX
may experience the following (highly annoying) issue. After 720 hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error Code
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-08/msg00472.html
Posted on Mar 01, 2011
E1 Error on air conditioner
It's time to call a professional. Call the manufacturer and ask them who they recommend in your area. Note :Some questions can be answered if you put enough information such as brand and model number.
Mar 25, 2017 | Haier HWR08XC7 Air Conditioner
I get a E1 error code on my window ac unit. What
Indoor room temp sensor defective. Replace it.
May 26, 2010 | Haier hwr10xc6 Air Conditioner
What does E1 flashing on display mean? The air conditioner comes on for 10 mins. and then flashes E1 in the display. I have cleaned filter b lown out grill and still no results.
if its a sharp ac ... it will need to be reset..
1) hold down the on/off button keep it held down and plug in the ac ..you should hear a beep...
2) hold down the mode button keep it held down and plug in the ac ..you should hear a beep...
one of two ways will reset the e1 error hope it helps..
Sep 19, 2009 | Heating & Cooling
E1 error code
my AC is going on 5-6 years, it's never failed me until the years. The Error E1 code hes been coming on lately.
i wait a few MIN's, then try again. about the 7-10 tries the unit comes on.
1. what is a error code 1
please reply to:
Derrick holiday
Email.... [email protected]
thank you.
dh
Aug 03, 2009 | Samsung AW1293L Air Conditioner
E1 error in hitachi ac
You can either ring Hitachi service number and they should be able to tell what the error is or if it is new and you had it installed by a licensed person. Call the person who installed it, as it should be under warranty by them.
Jul 19, 2009 | Haier Preference Plus HWR24VCA Air...
E1 error code on air conditioner
I called haier about this error code. E1 indicates that a button on the control panel or the reomote is stuck. I was instructed to unplug the unit and push each button at least 5 times, one at a time. Plug the unit back in, and this fixed my problem with error E1 and the unit works fine.
Jun 23, 2008 | Haier HWS08XC1 8,000 BTU Window Air...
Heating & Cooling Logo
728 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
