Samsung HT-DS630T System Logo
Posted on Mar 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Door wont open & It wont play - Samsung HT-DS630T System
T-Comtech Repairs
Level 2:
Guru:
  • Expert 417 Answers
  • Posted on Mar 01, 2011
T-Comtech Repairs
Expert
Level 2:
Guru:
Answers
417
Questions
Helped
110864
Points
317
How do you know it wont play, if you can't get the tray to open?
Door open wont
Open it with the remote & then remove
the door panel & find out why the key won't work
My Marantz CD 53 CDplayer door is not opening. what is the solution
You probably have a broken belt on the cd tray so it's neither open or closed, if the laser's ok thats why it wont play
My door on my 2004 chevy aveo wont open from the inside
Usually the shops don't actually fix a thing
They just put it back together & send you
on your way, without installing new parts
& doing the job correctly
My dad put the child proof lock on and now the rear door wont open at all help 2009 f 150
You will have to take door panel loose to open door & fix the rods inside the door .call me if you need help 8174570887
1998 Gmc Sierra, door wont open at all
see if you can pull the outside handle out a little & put some needlenose pliers in the opening & grab the rod to open the door. otherwise unscrew the door panel & get into the inside of the door that way.
good luck
1helpful
My LITEON 5045GDL+ dvd drawer wont open.
HI, you have two issue here. the load motor is malfunctioning. this is causing the door open and close feature to lock up. this motor is connected to the gear assembly. it should be replaced soon. the second issue is the optical lens assembly. this len assembly has failed. the laser is burned ut. this is causing the no play issue.
In conclusion, i recommend replacing the optical len assembly and the load motor as well. this will fix this issue. try not to force the door open often, this Will damage the loading dock gears.
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
