Question about Microsoft Windows XP Professional
NTLDR is missing is displayed when i turn on the computer
Posted by doypats on
Michel Smith
  • 1,218 Answers
The "NTLDR is missing", error displays very shortly after the computer is first started; after the Power On Self Test (POST) is complete. Windows XP might only initially load when the NTLDR error message appears. Causes of this error message include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Get more help and information for Windows XP hope this helps you.
Posted on Mar 07, 2011
Hans Pedersen
  • Microsoft Master
  • 3,606 Answers
Hope this site can help:
http://www.tech-pro.net/howto-fix-ntldr-is-missing.html
Good luck.
Posted on Mar 01, 2011
Anonymous
    New Friend:
  • 22 Answers
Understand the causes of missing NTLDR errors. One of the most common reasons for an NTLDR-based startup error occurs when Windows XP attempts to start from a hard drive that isn't set up to launch Windows XP. For example, you may encounter an NTLDR error if you attempt to boot from an improperly formatted Windows XP startup disk. These errors may also be caused by corrupt, missing hard drive data and loose hardware cables.
  • 2Click the Start menu button in the lower left-hand corner of the Windows XP screen. Select "Restart" to reboot the PC.
  • 3Check that the computer's optical media drives are empty. A major cause of NTLDR errors is when a non-startup disk is in the CD slot and Windows XP attempts to launch from it.
  • 4Insert the Windows XP installation disk. Restart the computer. Press any key on your keyboard during the startup process to launch the installation setup screen. Press the "R" key on your keyboard when the Windows XP Setup screen appears. This launches the Windows XP Recovery Console program and a screen in which you can type command prompts.
  • 5Type "copy d:\i386\ntldr c:\" (without quotation marks) in the command prompt window, then press the Enter key on your keyboard. Type "copy d:\i386\ntdetect.com c:\" (without quotation marks), and press the Enter key again. The Windows XP Setup software will detect and replace any NTLDR software files that may be missing or corrupt.
  • 6Press the "Y" key on your keyboard if the Windows XP Setup software asks for permission to rewrite and replace the files in Step 5.
  • 7Eject the Windows XP installation disk by pressing the Eject button on the front of your computer. Type "exit" (without quotation marks) in the command prompt window to close the Setup software, then press the Enter key on your keyboard to restart the PC. Windows XP will now launch without missing NTLDR errors.
  • Posted on Mar 01, 2011
    2 Related Answers
    halbrook
    Liza Halbrook
    • 560 Answers
    SOURCE: whenever i switch on my system, it displays NTLDR MISSING.
    looks like you have a corrupted MBR, this will fix the problem if its MBR
    1. boot to Windows XP CD
    2. Choose the Recovery Console
    3. Type your admin username
    4. Type your admin password if you have one set
    5. Type Fixmbr
    then restart and remove CD
    10. Load windows !
    11. Enjoy !
    Posted on Nov 10, 2009
    elix0411
    Jose Cada
    • 3530 Answers
    SOURCE: when i boot hte computer the ntldr is misssing???
    you might have accidentaly deleted th ntldr boot application. one way to solve this without formating your harddrive is; take out your harddrive and put it in to the computer as a slave drive with same operating system and copy the ntldr file. this file actually located at the C:\ drive and is actually hidden. just tick all show hidden file under folder options then VIEW TAB inorder to view and copy this file to your harddrive. once done, take our your harddrive and set again the jumper settings to Master then put it in to your computer. power on the computer and it should be working after this procedure. Else fails, you need to use the recovery disk that came with the system and restore the computer back to its factory setings.
    thanks and have a good day!
    If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
    Posted on Apr 06, 2010
    NTLDR Missing or what?
    You would have deleted the small kb file which contains the information of NTLDR from C: drive , Just download hire boot from net and boot it the first option in that you will see FIX NTLDR
    Jan 21, 2014 | Dell Computers & Internet
    My pc says input signal out of range and ntldr is missing what do i do
    Hi
    No input signal is displayed on my computer screen means your monitors refresh rate has been set at too high a frequency
    To fix this you need to start your p.c in safe mode(press f8 at start up)
    On the desktop go to control panel>display properties>settings>advanced>monitors>th... change the refresh rate to the lowest ,normally 60hz, make sure the box is ticked.
    Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
    Regards and thank you for using Fixya !
    May 21, 2011 | HP Computers & Internet
    Nltdr missing
    How To: Fix "NTLDR is missing"
    Applies to: Microsoft Windows NT, Windows 2000, Windows XP
    Symptoms
    When you start your computer, you receive the error message "NTLDR is missing. Press any key to restart."
    Cause
    The error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This oftenoccurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the driveconfiguration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has beencorrupted or deleted.
    SolutionCheck the boot drives
    First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one thatcontains Windows.
    • Check that there are no CDs or DVDs in the CD/DVD drives.
    • Check that no removable drives are plugged in to the USB ports.
    • Check the boot order in the BIOS Setup to ensure that the computer boots from the drive containing Windows before any other bootable devices.
    If this does not resolve the problem, you will have to repair the NT boot loader.
    Fix NTLDR
    The easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this anduse the Recovery Console to fix NTLDR manually instead.
    Use Spotmau PowerSuiteInsert the Spotmau PowerSuite CD and start the computer. The main menu will appear.spotmau-2.gif
    • Click 2. Windows Recovery.
    • When the Windows Recovery tool starts, click Windows NT/2000/XP/2003.
    • On the Windows NT/2000/XP/2003 Recovery dialog, click Recover NTLDR and NTDETECT.
    • On the Recover NTLDR and NTDETECT dialog, select your operating system (e.g. Windows XP) and then click Recover.
    The tool will repair the file and report "NTLDR and NTDETECT have been recovered successfully."
    • Remove the Spotmau PowerTools CD from the drive and click Restart to reboot the computer.
    Here link of the program Spotmau PowerSuite 2010 + Serial Download
    Here link of the program Spotmau PowerSuite 2010 v5.1.1.4846 Download
    Please Rate Me
    Nov 17, 2010 | HP Pavilion dv6000z Notebook
    NTLDR is missing error on starting the machine
    When a PC system or notebook displays NTLDR is missing you can still recover with out re-installing windows. Follow the instructions on the link provided; http://www.computerhope.com/issues/ch000465.htm
    Scroll down to: Corrupt NTLDR and/or NTDETECT.COM file.
    The fix is a bit different for Win 2000 &Win XP.
    Mike
    Oct 17, 2009 | Systemax Neotach 3300 Notebook
    NTLDR IS MISSING for HP 530
    1. Insert the Windows XP bootable CD into the computer.
    2. When prompted to press any key to boot from the CD, press any key.
    3. Once in the Windows XP setup menu press the "R" key to repair Windows.
    4. Log into your Windows installation by pressing the "1" key and pressing enter.
    5. You will then be prompted for your administrator password, enter that password.
    6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
      copy e:\i386\ntldr c:\
      copy e:\i386\ntdetect.com c:\
      Once both of these files have been successfully copied, remove the CD from the computer and reboot.
    Jul 28, 2009 | Computers & Internet
    Black screen with messege( ntldr is missing)
    If ntldr is missing either the computer is trying to boot off the wrong device(usb drive, floppy, memory chip, etc) or the boot sector on your harddrive may be damaged.
    Remove any and all removable disks, including cd's/dvd's, reboot the computer and try again. If you get the same message then your harddrive is either corrupted(software problem) or damaged(physical failure).
    Let me know how this works out, don't forget to unplug things like printers or cameras that have memory card reader, even if there's no chip in them.
    Hope this helps, let me know if it doesn't and I can provide you with the next steps.
    Chris
    May 27, 2009 | AMD Athlon 64 X2 5200+, 2.6 GHz
    NTLDR is missing
    Reference number: CH000465
    NTLDR is Missing. Issue:NTLDR is Missing.
    Related errors:
    Below are the full error messages that may be seen when the computer is booting.
    NTLDR is Missing
    Boot: Couldn't find NTLDR
    Please insert another disk
    NTLDR is missing
    Press Ctrl Alt Del to Restart
    Cause:
    1. Computer is booting from a non-bootable source.
    2. Computer hard disk drive is not properly setup in BIOS.
    3. Corrupt NTLDR and/or NTDETECT.COM file.
    4. Misconfiguration with the boot.ini file.
    5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
    6. New hard disk drive being added.
    7. Corrupt boot sector / master boot record.
    8. Seriously corrupted version of Windows 2000 or Windows XP.
    9. Loose or Faulty IDE/EIDE hard disk drive cable.
    You can go to these sites to view solutions (to much to post here) Very easy to understand:
    May 22, 2009 | E-Machines eMachines Desktop PC
    IntelLoader is missing
    I think your computer displays a message that ntldr is missing.
    Use the following steps to replace these files. Insert the Windows XP bootable CD into the optical (CD or DVD) drive and restart the computer.
    1. When prompted to press any key to boot from the CD , press any key on the keyboard.
    2. Once in the Welcome to Setup screen, press the R key to repair Windows.
    3. Press the 1 key and then press Enter .
    4. Type the Administrator password at the prompt.
    5. Copy the NTLDR and NTDETECT.COM files to the root directory using the following steps:
      1. Type copy d:\i386\ntldr c:\ (assumes the optical (CD or DVD) drive is d) and then press the Enter key.
      2. Press the Y key at the Overwrite ntldr? prompt.
      3. Type d:\i386\ntdetect.com c:\ and then press the Enter key.
      4. Press the Y key at the Overwrite ntldr? prompt.
    6. Once both files have been successfully copied, remove the CD from the optical (CD or DVD) drive and type exit at the prompt and then press the Enter key. The computer will reboot.
    Nov 24, 2008 | Microsoft Windows XP Professional With...
    Microsoft Windows XP Professional Logo
    834 people viewed this question
    Top Microsoft Computers & Internet Experts
    Lee Hodgson
    Lee Hodgson
    efs_perpends
    efs_perpends
    ThaMp3Doctor
    ThaMp3Doctor
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
