must follow exactly for full help topics i offer a cd with all settings for every provider along with hundreds of java games wallpapers and mp3 ringtones. if interested submit 10 us dollars to
[email protected]. will send as soon as payment is eceived in padded envelope first class mail.
SMS Messaging:
1.) From the main screen tap the SMS Text icon.
2.) Tap SMS on the Messages menu.
3.) Tap SMS settings on the SMS menu.
4.) Tap either SIM1 or SIM2 on the SMS settings menu, whichever SIM you are setting
up at this time for SMS messaging.
5.) Tap Profile settings on the SIM1(2) message settings menu.
6.) Tap on any unused profile to select it, then tap the Edit button on the bottom of the
screen.
7.) You should be on the Profile name menu with the name field already highlighted. Go
ahead and tap the Edit button at the bottom of the screen.
8.) Tap in the following text between the quotes in the Profile name editor:
?T-Mobile?
Next tap the Options button at the bottom of the screen. Next tap the Done button.
You should be back on the Profile name menu with the new name.
9.) Tap the area below the profile name. The top of the menu should change to read SC
address and the bottom of the screen should show a numeral keyboard.
Tap in the following text between the quotes in the SC address editor:
?+12063130004?
Next tap the OK button at the bottom of the screen.
10.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
You are done setting up SMS messaging for T-Mobile. You can continue
to tap the Back button on the bottom of the screen until you exit out of all
the menus to the main screen, or simply press the On/Off button once to
get back to the main screen. At this point you can test SMS messaging by
sending yourself a text message, or continue with other setup of the
phone.
The next sections will show you how to set up MMS messaging as well
as an internet connection if you are paying for T-Mobile?s internet access
services. One note about internet services, as a T-Mobileweb customer
you can get full access to anywhere on the internet if you install & use a Java based web
browser such as Opera Mini instead of the internal browser of the phone, and as of
this writing you don?t need to be on their much more expensive internet plan, the simple $5.99
T-MobileWeb plan will work! You can get Opera Mini here => MASTER Download List
Our next step will be to set up the data connections you will need to use. If you are not going to
use the internet or will only be accessing T-Mobile?s T-Zones, then you only need to set up the
first data account service we will name T-Mo MMS, otherwise if you want to access the full
experience of the internet, please set up both data account service connections outlined in the
next section.
Don?t worry if at any time you exit from one of the menus and find yourself back at the slidelock
screen, simply just slide unlock the phone and continue from where you last left off!
Data Account Services:
1.) Setting up regular data account services for MMS & T-Zones access.
2.) From the main screen tap the Service icon.
3.) Tap Data account on the Services menu.
4.) Tap GPRS on the Data account menu.
5.) Choose any of the profiles in the current list and tap the button.
6.) You are now on the Edit screen.
7.) Tap the area just below Account name, then tap Edit at the bottom of the screen.
?T-Mo MMS?
Tap the Options button at the bottom of the screen.
Tap the Done button.
9.) Tap the area just below APN, then tap the Edit button
10.) Tap in the following text between the quotes
?wap.voicestream.com?
11.) Both the User name & Password areas should remain
BLANK. If they are not blank, then tap on each one
and Clear what is in them so they are both blank.
12.) The Auth. type should be set to Secure. If it is not, then tap on the area and use the
arrows to move the selection so it has Secure, then tap Done.
13.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
14.) Tap Back button on the bottom of the screen. Tap Back button again on the bottom of
the screen. You should now be on the Services menu.
15.) Tap WAP on the Services menu.
16.) Tap Settings on the Internet services menu.
17.) Tap Edit profile on the Settings menu.
18.) Tap either SIM1 or SIM2 on the Edit profile menu, which ever SIM you are setting up
at this time for MMS messaging.
19.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but
profile 8 is usually the first not already filled.
20.) Tap on Profile 8. Tap Edit profile.
21.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen.
22.) Clear the current text, then tap in the following text between the quotes
?T-Zones?
23.) Tap the area below Homepage, then tap on the Edit button at the bottom of the screen.
24.) Clear the current text except for ?HTTP://?, then tap in the following text between the
quotes after the HTTP://
?wap.myvoicestream.com?
25.) Tap the area below Data account, then tap Select at the bottom
of the screen.
26.) Tap GPRS on the Data account menu.
27.) Scroll down the list until you come to T-Mo MMS, the data
account set up earlier under the Data Account Services
section. Tap on T-Mo MMS to select it.
28.) Tap the area below Connection type, then tap Select at the
29.) Tap on HTTP, then tap on OK at the bottom of the screen.
30.) Tap the area below Proxy address, use the numeric keyboard at
the bottom of the screen to tap in the following numbers,
?216155165050?. The result should look like 216.155.165.050
under Proxy address.
31.) Tap the area below Proxy port, use the numeric keyboard again
to tap in the following numbers ?8080? to replace the current 0
value.
32.) Tap the OK button on the bottom of the screen.
33.) The areas under both User name & Password should remain
BLANK. If they are not blank, select each, and Edit them by
clearing all text.
34.) Next tap the Done button at the bottom of the screen.
35.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
36.) Tap the Activate profile button on the T-Zones menu screen, and you should be taken
back to the Select profile screen where a big green check mark will be beside the newly
saved T-Zones profile.
37.) Tap the On/Off button once to exit to the main screen.
38.) If you ONLY want MMS and T-Zones access without the full internet connection,
you can now skip down to the MMS Messaging section and continue setting up MMS
messaging; otherwise continue below at step 39 to set up a second data account service
which will be used for your internet connection.
39.) Setting up a 2nd data account service for full internet access.
40.) Tap the Service icon on the main menu.
41.) Tap Data account on the Services menu.
42.) Tap GPRS on the Data account menu.
43.) Choose any of the profiles, other than T-Mo MMS, in the current list and tap the
button. The profile right under it would be fine.
44.) You are now on the Edit screen.
45.) Tap the area just below Account name, then tap Edit at the
46.) Tap in the following text between the quotes
?T-Mo Internet?
47.) Tap the area just below APN, then tap the Edit button at the
48.) Tap in the following text between the quotes
?epc.tmobile.com?
49.) Both the User name & Password areas should remain
BLANK. If they are not blank, then tap on each one and Clear
50.) The Auth. type should be set to Secure. If it is not, then tap on the area and use the
51.) A Save? question box should pop up. Tap the Yes button at the bottom of the screen.
52.) Now that you have set up a second account service for internet use we can adjust the
WAP settings for T-Zone to use this faster and less restricted internet gateway.
53.) Tap the On/Off button once to return to the main menu.
54.) Tap the Service icon on the main menu.
55.) Tap WAP on the Services menu.
56.) Tap Settings on the Internet services menu.
57.) Tap Edit profile on the Settings menu.
58.) Tap either SIM1 or SIM2 on the Edit profile menu, whichever SIM you are setting up
59.) Tap T-Zones on the Select profile menu.
60.) Tap Edit profile on the T-Zones menu.
61.) Tap the area below Data account on the Edit profile menu,
then tap the Select button at the bottom of the screen.
62.) Tap GPRS on the Data account menu.
63.) Find and tap on T-Mo Internet on the Data account menu.
64.) Tap the Done button on the bottom of the Edit profile menu.
65.) A Save? question box should pop up. Tap the Yes button at
66.) Tap the Activate profile button on the T-Zones menu screen, and you should be taken
67.) Tap the On/Off button once to exit to the main screen.
68.) Continue below with setting up MMS messaging.
MMS Messaging:
2.) Tap MMS on the Messages menu.
3.) Tap MMS settings on the MMS menu.
4.) Tap Server profile on the MMS settings menu.
5.) Tap either SIM1 or SIM2 on the MMS settings menu, whichever SIM you are setting up
6.) Scroll down the list until you come to Profile 8. You can use any profile if need be, but
7.) Tap on Profile 8. Tap Edit profile.
8.) Tap just below Rename profile, then tap on the Edit button at the bottom of the screen.
9.) Clear the current text, then tap in the following text between the quotes
?T-Mo MMS?
10.) Tap the area below Homepage, then tap on the Edit button at the
11.) Clear the current text except for ?HTTP://?, then tap in the
following text between the quotes after the HTTP://
?216.155.174.84/servlets/mms?
12.) Tap the area below Data account, then tap Select at the bottom of
the screen.
13.) Tap GPRS on the Data account menu.
14.) Scroll down the list until you come to T-Mo MMS, the data account
set up under the Data Account Services section. Tap on T-Mo MMS
to select it.
15.) Tap the area below Connection type, then tap Select at the bottom of
the screen.
16.) Tap on HTTP, then tap on OK at the bottom of the screen.
17.) Tap the area below Proxy address, use the numeric keyboard at the
?216155165050?. The result should look like 216.155.165.050 under
Proxy address.
18.) Tap the area below Proxy port, use the numeric
keyboard again to tap in the following numbers
?8080? to replace the current 0 value. Then tap OK.
19.) The areas under both User name & Password should
remain BLANK. If they are not blank, select each,
and Edit them by clearing all text.
20.) Next tap the Done button at the bottom of the screen.
21.) A Save? question box should pop up. Tap the Yes
22.) Tap the Activate profile button on the T-Mo MMS menu screen, and you should be
taken back to the Select profile screen where a big green check mark will be beside the
newly saved T-Mo MMS profile.
You are done setting up MMS messaging for T-Mobile. You can continue to tap the Back
button on the bottom of the screen until you exit out of all the menus to the main screen, or
simply press the On/Off button once to get back to the main screen. At this point you can test
MMS messaging by sending yourself a picture message.
Internet Access:
If all you want to use for internet surfing is the phone?s built-in browser, and you have set up
the data account service for the internet in the earlier setup, then you are ready to surf the
internet by simply tapping on Service from the main menu. Then tapping on WAP and using
the various options to navigate the internet like Homepage, Input address, etc. However, this
won?t provide as robust an internet experience as a Java based internet program such as Opera
Mini 3.1 or 4.1, or another java based internet browser. If you do decide to install a Java
program for browsing the internet, there is one more setting which must be changed prior to
using the Java internet browser.
Java Internet Settings:
1.) From the main menu tap on the Java icon.
2.) Tap Java settings from the Java menu.
3.) Scroll down and tap the area just below Java SIM1 (SIM2) profile,
which ever SIM you are currently setting up.
4.) Use the arrows to scroll the setting until T-Zones appears in the
box.
5.) Tap the OK button at the bottom of the screen.
Now you should be completely set up for SMS, MMS, as well for
internet on the T-Mobile network if you have a T-Mobile internet
plan!
