Question about Casio Edifice 10YearBattery Bracelet #EF106D2AV Watch for Men
How do you remove a link off the Casio Men's Edifice 10-Year-Battery Analog Bracelet Watch #EF106D-2AV?
Posted by esdoppert on
Robin Bonathan
  • 699 Answers
Have a look at the links nearest the clasp.
These should have markings on to say which are removable. An arrow or some other indication.
Not sure if this watch has press pins that go through the whole bracelet or flip up catches on each band.
Please dont forget to vote this answer was helpful.
Many thanks
Posted on Mar 01, 2011
Change time in cassio edifice
Here is the link that includes step by step procedure including visuals.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2711.pdf
I hope this will help you a lot
Thank you for choosing fixya.
Mar 02, 2011 | Casio EF-500D-2A Edifice Chronograph watch...
HOW DO I SET THE TIME FOR MY CASIO WAVECEPTOR MODEL WVQ142DA-2AV
Thanks for contacting FixYa.
The Waveceptor is such a complex watch that they have devoted an entire website/help for just this brand. I have given you a link to help out. Best regards. Jewel
http://waveceptor.casio.com/support/
Sep 02, 2010 | Casio Wvq142da 2av Waveceptor Bold Watch...
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    How to shortend the metal band
    On most brands, there are pins that form hinges for the links of strap. You need to push them out. usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
    http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
    which should help you to remove the link pins safely without scratching.
    Sep 30, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
    Adjust-a-Casio-S-1087DY-Watch-Band
    On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
    Aug 31, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
    Had new battery now watch 4 hours behind CASIO WAVE CEPTER
    It sounds like your in the wrong time zone and day light saving is in the wrong mode.
    Sep 06, 2008 | Casio Wave Ceptor Atomic Silver Tone with...
    Remove few pieces in my Casio AW-SD bracelet
    What u can do is call casio tech support and give them ur email address and they can send you the instructions to adjust your band.
    Jun 07, 2007 | Casio AWS90D-2AV Wrist Watch
    Casio Edifice 10YearBattery Bracelet #EF106D2AV Watch for Men Logo
    886 people viewed this question
    Top Casio Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Ekse
    Bruce Robin
    Are you a Casio Watch Expert? Answer questions, earn points and help others
