Question about Singer 1725
Do not know how to set the machine for simple straight stitch.
Posted by walbanktom on
Tally Girl
  • Singer Master
  • 1,134 Answers
I don't know your model but most machines have 2 common setting devices, namely a stitch width dial (how wide the needle swings) and a stitch length dial, how far apart the stitches are. So a normal straight stitch is "width" set to zero and "length" set to 2.5. If the machine has several different stitches then there may be a "stitch selector" too where you can choose the stitch style, ie zig-zag, 3 step zigzag, blind hem stitch etc.
You could try to locate a manual or threading diagram at various websites or visit sewing.about.com which gives good general information on threading and use.
Posted on Mar 01, 2011
5 Related Answers
Anonymous
SOURCE: shark 384 - how can i get a straight stitch?
Set it zigzag mode and set the stitch width dial (lower dial on right side) to zero. That should give you straight stitches.
Posted on Nov 19, 2007
Anonymous
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
bargainbox
Hassy
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jul 24, 2008
Anonymous
  • 118 Answers
SOURCE: Purchased a viking 6440 at a house sale without the instruction
you can download the actual manual from this page: good luck.
http://ucanprint.net/Brand/viking_manuals.htm
Posted on Jul 25, 2009
Anonymous
  • 16 Answers
SOURCE: How do I do a stretch stitch?
The bes way to hem a t-shirt on a household machine is to use a double needle, straight stitch. You will see two straight stitches on top and zig zag on the back. Just make sure the zig zag catched the top of the hem.
Posted on Aug 02, 2009
Help please. How to adjust presser foot. Where to chg stitch length
Please provide the make and model of your machine. There is generally no adjustment to the presser foot for selecting a straight stitch. You just need to use the specific presser foot that the owner's manual recommends for a straight stitch. The adjustment is made to the stitch length and stitch width selectors. But, since we don't know which machine you have, we can't help.
Search for:
Make Model manual
Aug 26, 2017 | Sewing Machines
What should my settings be for a simple straight seem with my Singer Simple sewing machine?
Make sure the stitch "width" is set to zero and no decorative stitches have been selected.
Nov 15, 2016 | Singer Sewing Machines
I just worked with my Shark sewing machine and it was fine suddenly it stopped zig zag and start working simple stitches! Can you let me know why it happened? There was no noise or sound of breaking.
There is a spring that got loose from the needle arm that keeps pressure on the arm. It needs to be reattached. Anyway, make sure all of the normal adjustments are set properly. Just one adjustment wrong will cause the machine to only run in a straight stitch. Possibly a button hole or something else. Remove the top of the machine and look down where the needle arm is. The needle arm bracket has got to pull the arm towards the arm using the pressure of an attached spring. This spring is hanging inside the machine from a permanent side bracket. If it isn't there then it has dropped to the bottom of the machine. Anyway, the needle arm must have the sideward pull in order for the machine to produce a zigzag stitch.
Aug 05, 2016 | Sewing Machines
Our simple 3116 won't zigzag stitch,the needle is off to the right and will not do any other stitches. Help!!
It won't do straight stitch?
Take the needle out... see if it is moving the fabric when you press on the presser foot. If it is not, then you need to raise the feet (it's under the accessory box/table face. If it does move the fabric. Make sure your machine is set to Zig Zag. again without needle... sew. Does the needle bar move? change to straight stitch, does the needle bar move? If it does I think you have the wrong size needle. If it does not, I'm afraid your plastic machine has broken... take it in for repair.
Oct 04, 2014 | Singer 3116 Simple
How do i get a straight stitch on my golden touch & sew model 640 machine
Check for diagrams on the selector wheel and then adjust your stitch length. Do not set to tight as your thread will break
Oct 02, 2014 | Singer Sewing Machines
Does anyone know how to set a Brother sewing machine for a straight low tension stitch?
Stitch length on 2.5 and stitch width on zero, and just loosen the top tension by a half number if you want the tension looser. If your machine has a stitch selector knob, make sure it is set to the straight stitch setting.
Oct 10, 2011 | Brother XL-2600I
I don't have a manual for a Husqvarna 6440 and don't know how to switch from zigzag to straight stitch. Everything else seems to be sewing beautifully and it was on straight stitch when I first tried it. I...
You have 3 knobs/dials on the machine, the top left dials the stitch, the top right sets the length and the bottom right set your width. set it 0 for straight.
Mar 03, 2010 | Sewing Machines
Feb 19, 2009 | Kenmore 12102
Sewing Machine Stops
this sounds like its set for zippers check settings!
Dec 09, 2008 | Husqvarna Sewing Machines
Singer 1725 Logo
647 people viewed this question
Top Singer Sewing Machines Experts
tsalagi152
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
