Question about Ovens
Hi.. I have a wall oven fisher & paykel model 600e and after my girlfriend tried to use it pressing all the buttons without knowing what she was doing the element is not heating up anymore :( what should i do??? Tx
Anonymous
    Champion:
  • 235 Answers
The electronic timer must be in manual mode for the oven to work. Turn the oven on. Play around with the clock/timer buttons using as many combinations as you can. When the oven indicator light comes on the clock/timer is in manual mode. This could take 5 minutes or more. Be patient.
Posted on Mar 01, 2011
  • 2 more comments
  • Anonymous Mar 01, 2011
    everything seems to be working fine but the element is still not heating up
  • Anonymous Mar 02, 2011
    Okay I need to know one thing to help you. When you turn the oven on does the oven indicator light come on? If it does it is more than likely that the oven element is blown. If it does not come on then we have a supply problem probably at the oven control.
    Well.. The oven temperature light on the front panel and the internal light both come on and the fan is working. The only thing not working is the element :(. I thought it could be a kind of child lock or something like this. I dont have the oven's manual and cant find it on the internet also. I used it last week and was working fine. Cant imagine how could it be blowned just like that. It didnt smell at all.
  • Anonymous Mar 03, 2011
    With the information you have provided the oven element will be blown or the wiring at the terminals of the oven element will be burnt off. You can check the element visually for any blow marks and check the terminal wiring. Sometimes it will be an internal fault which cannot be seen. If the indicator light and fan are working it has to be an element problem.
I have a built in fisher and paykel oven. How do I set the clock
no model doesnt help normally the two left buttons and the second to last button all tghree pressed at the same time
2helpful
How to set clock on saffron stove fisher and paykel
as it shouls calways be off at the wall when not in use, but if you want to then press the two left and the second to last button all at the same time
Only numbers I can read on Fisher and Paykel Freestanding Multifunction oven to set clock after power outage are 87042 RA61OMEW34
to be honest you should always turn it off at the wall when not in use for safety reasons most common one is to press the two far left buttons and the second to last button all at the same time
How to reset clock on Fisher & Paykel stove
i would not bother to be honest as a safety thing your supposed to switch it off at the wall when not in use toprevent chance of a house fire;
i am guessing its digital if so press the two left buttons and the to last button at the same time
Fisher & Paykel OR90 Oven just turned it self off and wont work the only thing working is the digital clock.
sounds like its gone in to automatic mode,try pressing the left two buttons and the second to last buttons at the same time
2answers
I have a fisher & paykel paprika and i cant get
Hi - Are you able to provide model number of the oven - or describe the front controls as they have about 6 different types of controls regardless of the brand name 'paprika'
cheers
Hi, I have a wo570xd double oven and the controller is playing up, ihave had F& P send me a new controller (572942p), this controller did not work so contacted them again and they have sent out a new...
fisher & paykel oven model WO570XD seems to be no power from source to the wall oven however range top works fine. Power light on switch to oven is illuminated indicating there is power however there is no lighting on digital display unit. Any help appreciated
I used the Self Cleaning feature on my Fisher & Paykel OS302 wall oven for the first time, and now the oven will not heat. The lights and fan run, but no heat.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
10helpful
2answers
FISHER AND PAYKEL MODEL BICT600E AND SERIAL 87436
Press the two left buttons at the same time and hold them in, then use the + and - buttons on the right to set the required time.
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Are you an Oven Expert? Answer questions, earn points and help others
