Question about Samsung WF448AAW 4.5 cu. ft. Front Load Steam Washer
I have a 5 month old samsung steam front loader that gives an error message of d5 . What does it mean and how do I fix it
Posted by nsouthall on
softwarealli
    New Friend:
The door is not sensing that it is closed. open it and re close the door again, make sure it is closed all the way, if it is and it still gives you this error, unplugg the machine, close and open the door again, and plug it back in and try again. if this doesn't work, you'll need to have a repairman take a look at your washer.
Posted on Aug 04, 2011
Samsung front load washer code d5
The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. the problem is related to faulty door locking assembly.There is a switch in back of door, if this fails it wont work. God-Bless!
Nov 06, 2015 | Samsung Washing Machines
I need a Samsung Vrt steam manual. What does the error message 3E stand for on the, VRT Samsung Front Loader washing machine?
This video will help you diagnose the fault on Samsung Vrt steam 3e error codes and the video will help you solve the problem
Oct 24, 2015 | Samsung 3.9 Cu. Ft. VRT Steam and Power...
I have a amana front loader washer and it was doing its norman cycle and stopped at 35 min left and wont do anything and the door was locked so I unplugged it for a hour went back and pluged it in makeing...
This is an error involving the door switch, it is actually DS not D5. The door may not be closed properly, try pushing it in. Or you may need a replacement door switch.
Jan 27, 2015 | Amana Washing Machines
I have a Samsung front loader. It has been stopping with the error code 5E (filter problem ) for a few months now. Turning the machine off then on again after 20min gets it going again. The fault always...
The 5E error mean:
Pump won’t empty - not draining
As usual with these error codes for not draining the first thing to do is check the pump filter but, on Samsung washing machines, the drain pump itself is often faulty. You can find how to fix this problem on youtube, just text it "Samsung washing machine 5E error".
May 16, 2017 | Samsung WF520ABP - 5.0 cu. ft. Steam...
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
Not sure if this is the right wasing machine that matches ours or not but we are getting a d5 error and don't know what it means
The error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle.The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly.But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem. This has to be checked to confirm the fault.Keep updated with any more queries.Thanks.
Oct 14, 2010 | Samsung WF337AA Front Load Washer
My samsung front loader is only 6 months old and already it is showing the nf code meaning it is not filling with water, yet it is. How can we fix this??
what do you maen its not filling? is it washing is there a full load?has any thing chaned or are you doing any thing different when you got it? check and make sure the fill hose is not kinked the valved is on all the way. try these and let me know.thanks
Aug 29, 2010 | Samsung WF337AA Front Load Washer
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Door wont lock
door won't lock & shows d5 code what do i need to fix it?
Dec 18, 2009 | Samsung WF203ANW Front Load Washer
Samsung WF448AAW 4.5 cu. ft. Front Load Steam Washer Logo
598 people viewed this question
Top Samsung Washing Machines Experts
Marvin
Marvin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
