Question about Nikon COOLPIX S60 Digital Camera
I have a nikon coolpix s60 and when i go to view the pictures, the screen turns black and i cant turn the camera off unless i pull the battery
Posted by daliari72 on
Anonymous
    New Friend:
What name brand memory card do you use? I recently discovered myself that Nikon only supports SanDisk, Toshiba, Panasonic and Lexar. Try taking out the memory card and take pictures without the memory card inside the camera. If you can view the picture saved onto the camera memory then you will know that all you need is a new memory card, with one of the above mentioned name brands. Hope this helps.
Posted on Mar 24, 2011
Doesn't turn on right away. stays black takes 40 seconds or more to take a picture then takes several more seconds to take thenext picture
Hi Pam,
This can be normal behaviour for some cameras, especially older ones. I don't think that you have anything to worry about unless this behaviour has only recently started. Have you raised this with Nikon customer support? Nikon Service and Support Nikon Customer Service Nikon Support
Aug 01, 2015 | Nikon COOLPIX S9500 Digital Camera Black
Nikon coolpix troubleshooting
I talked to Nikon and thats not suppossed to happen
return it back to Nikon for repair.
Aug 20, 2014 | Nikon Coolpix S6100 Digital Camera
My nikon coolpix s6300 won't let me view the pictures i have taken on the camera.
I can only offer this: (sorry if it does not help)
When the micro USB Cable is plugged into the camera you MAY be able to take photos. The camera MAY work normally EXCEPT for the MONITOR or Screen. The screen is TURNED off when you plug in the cord.
Nov 01, 2017 | Nikon Coolpix S6300 Hd Digital Camera
Camera won't take pictures
Try resetting the date and time.
Aug 18, 2009 | Nikon COOLPIX P60 Digital Camera
Screen and photos are black
CCD is BAD !!
just call Nikon i am sure they will doit Free becoz it is a manufac fault all manufacturers are doing it Freejust call them and ask them about BAD CCD !!
Pls rate me WELL !
Jul 03, 2009 | Nikon COOLPIX S60 Digital Camera
Nikon coolpix S51
Bad CCD, this is like film in a film camera. If the CCD becomes faulty it can no longer record images. This as a rule unless you can repair yourself is a repair not worth doing.
Jul 02, 2009 | Nikon Coolpix S50 Digital Camera
Nikon S60 LCD screen turned red and pictures now turn out wavy
If you have the receipt and store information and/or warranty registered, you may want to return for refund or exchange.
Feb 07, 2018 | Nikon COOLPIX S60 Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Problems taking pictures
Six months - Yes warranty.
Yes vendor still liable
Jun 14, 2008 | Nikon COOLPIX S6 Digital Camera
Nikon COOLPIX S60 Digital Camera Logo
Top Nikon Cameras Experts
Steven Wander
Steven Wander
Jax Planet
Jax Planet
Are you a Nikon Camera Expert? Answer questions, earn points and help others
