Question about Samson SX1200 Amplifier
Well,yeah, disabled amps and silence define self-protection. Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on. Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up. You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Eure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it. If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good. If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 01, 2011
Jul 30, 2015 | Dodge Cars & Trucks
Jan 23, 2018 | Cambridge Audio Azur 650A Integrated...
Dec 07, 2012 | 1994 Cadillac Eldorado
Sep 12, 2011 | Fender 150 Watt PA System
Apr 30, 2010 | Music
Jan 20, 2010 | Texas Instruments TI-30XA Calculator
Dec 25, 2009 | Televison & Video
Oct 25, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
Aug 28, 2009 | ASUS P4S533-E Motherboard
Oct 25, 2007 | Sony STR-DE345 Receiver
389 people viewed this question
