SOURCE: auto adjust
In case you have connected both the DVI and VGA cables to the back monitor can cause this problem. Try unplugging one of the cables and check if the problem gets resolved
SOURCE: Samsung Monitor MJ17VS
Check your refresh rate in your display driver properties. Try changing it to one of the available selections other than to what it's currently set to. It could be that the monitor is trying to match the signal received but can't quiet do it correctly.
SOURCE: Auto Adjustment keeps turning on every few seconds
I have had the same problem and now suspect that cleaning fluid from when I cleaned the screen may have seeped in. After a number of things I did over a period of 2 weeks the problem went away completely.
1. You may be able, if that is your problem, solve it quicker with a hair dryer at a distance (no melt down!)
2. Run HP diagnostics and clean the registry
3. Re- install drivers
Like I said I think 1 is the most likely. I went from every couple of seconds to completely solved.
Another possibility is that an MS update may have caused the problem and then another solved it.
SOURCE: computer monitor keeps auto adjusting screen
I don't know if this solution is credible to all monitors with this problem.... but have a gateway monitor and it kept doing that annoying "auto processing" flash while i worked...but i figured it out...for some wild reason i held down both the "auto" button and "contrast down" button and it fixed it. it will take a couple of tries but on a lucky push I did it and it went away and i havent had a problem since...I hope i have been a little help :)
SOURCE: Acer x193w LCD Monitor repeatedly auto configures.
Here is a link to get the manual:
http://www.acerpanam.com/synapse/data/7117/documents/X193W%20(Qisda)%20user's%20manual.pdf
Starting on page 15 are the directions for the monitor controls. Page 17 indicates a "RESET" feture to Clear the Old-Statuses of "Auto-Configuration". There are quite a number of setting for this monitor.
