Question about Frigidaire Refrigerators
Frigidaire Gallery FRS24XGCW Regrigerator is not cooling. The freezer side is about the temp of the normal refrigerator side.
Posted by Joseph Lucius on
  • Joseph Lucius Mar 01, 2011
    why? what will this tell me?
Wally Bald Guy
    Guru:
  • 683 Answers
Remove the grill along the bottom of your refrigerator. Locate the drip pan, using a flashlight if necessary. The pan should be sitting on a set of black condenser coils.
Remove the pan and wash it. Use a mixture of warm, soapy water and bleach to kill the mold.
Reinstall the pan and the grill.
Locate the coils. They look like thin, black radiators and may be underneath the fridge or attached to the back.
If the coils are on the back, pull the refrigerator away from the wall, then vacuum the dusty coils, using the brush and crevice attachments. Reinstall the refrigerator grill.
If the coils are underneath, pull off the grill and remove the drip pan. Vacuum the dusty coils, using the crevice attachment to get between them. Take care not to damage the delicate coils. Reinstall the refrigerator grill.
Posted on Mar 01, 2011
The freezer is fine steady at 0, but the refrigerator temperature keeps rising currently at 67 degrees.
Check the freezer make sure you do not have frost build up. Defrost problems choke out the air flow and if it happens the refrigerator will not cool.
Sep 15, 2015 | Frigidaire FGHS2342LF Gallery 22.6 Cu. Ft....
Frigidaire Gallery's refrigerator side stopped cooling
In side by side units, the freezer side actually cools the refrigerator side by a damper door/switch. Contact a professional if you don't find any blockages in the door area, and the temp does not change.
Aug 12, 2012 | Frigidaire FRS23H7CS Side by Side...
Freezer temp raises and water leaks out. then temp lowers and it works ok for a day or two then it repeats
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 04, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
I own a Frigidaire Gallery refrigerator model # frs24xgcw ,the freezer sidehas stopped cooling and there is an occasional buzzing noise. Refrigerator side is working.The refrigerator is approximately 11...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Jan 01, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Every now and then the temp for the freezer and the fridge side rises in the 50's for a couple hours.
Defrost timer is sticking...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 04, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer side works, other side does not cool
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you ti figure out why the refrigerantor is not cooling...
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
May 22, 2008 | Frigidaire Refrigerators
Frigidaire gallery model frs24xgcw
temp in the freezer should be about -8 what do you mean by iced up please real ice or heavy frost
Jan 30, 2008 | Refrigerators
Refrigerators Logo
189 people viewed this question
Top Frigidaire Refrigerators Experts
john h
jdthefixer
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
