Hitachi 53FDX20B 53" Rear Projection Television Logo
Posted on Mar 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Hitachi 53FDX20B projection TV. The Red color seems to bow. I have tried to perform MAGIC FOCUS to no avail. Additionally, I took the front panel off to manipulate the adjustable knobs. What I have come up with is that Blue and Green are good. When I turn red totally off, I get a good picture with no bows. What is the problem and what do I need to do to correct this issue myself?
Anonymous
Level 3:
  • Hitachi Master 5,138 Answers
  • Posted on Mar 01, 2011
Anonymous
Hitachi Master
Level 3:
Answers
5138
Questions
5
Helped
1004446
Points
13534
Problem will be either Bad resistors ,in front of the Convergence ICs or ICs and resistors need to be replaced. ICs are big black ICs and will have part number on them STK392-110 use 120s or 150s
Mats Electronics has Parts ask for Convergence repair Kit. 1-800-628-1118
Magic focus --blue and yellow sag in the upper left area of the screen
This is a problem with the convergence circuit. If you can solder, you can repair this yourself. First try and resolder the pins on the existing convergence ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. If the resoldering does not resolve the problem, replace the ICs.
Dan
Hitachi 53fdx20b and it has a wave acrost the top
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2helpful
2answers
Color convergence "whacked out"/blue shadow to right side
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Split colors on screen
Replace the two convergence Ics they are STK392-110 if your model is the 53FDX20B you can get replacement Ics with installation instructions at the following link.
http://servicemanuals.vstore.ca/
2helpful
Have a 53" Hitachi HDTV that bows at the top and the bottom. I was told one of the transitors or transformes blew. I also do not have the regular magic focus just the static focus now. I tried to alli
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
1helpful
2answers
When i turn on tv the screen is turning green
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence or magic focus section
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
HITACHI Projection TV 53FDX20B having too much red color
my hitachi projection big screen tv 57SWX20B has a draping affect across top of screen why?
53fdx20b double vision?
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
