Question about Toshiba e-Studio162D Copier
Pale copies and two vertical white streaks - Toshiba e-Studio162D Copier
Posted by stewiedotcom on
Alistair Chapman
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 44 Answers
I'm afraid that regarding pale copies, you are better off checking your consumables (toner, fusers, etc) and then try talking to Toshiba. However, the vertical white streaks can be caused by excess ink and other contaminants on the inside of the printer. If you open the main door to both the printer and finisher (if fitted) and look at all of the visible runners, feeders and other handling devices, try to see if any of them line up with your vertical streaks on a page. If so, try manually rolling them and cleaning them thoroughly. This might help remove some of the streaking (it did on mine).
Hope this helps, Alistair
Posted on Feb 28, 2011
Printed document has white streaks. I've replaced all toner cartridges AND replaced the toner waste unit. The streaking occurs when I print or copy but is much worse when I make a copy. Is there a printing...
If you are getting vertical white streaks or faded streaks from the top of the page to the bottom. It sounds like the developer blades in the imaging unit needs to be replaced. It cost around $120 to replace, but after a while it will happen again. This is a common problem with this printer. It can be cleaned by taking the unit apart and cleaning the developer blades, if you are handy. I have posted detail instructions in my tips section. or you can click on this link:
http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300.
Hope this helps.
Jun 13, 2010 | Samsung CLX 3160fn All-In-One Printer
Wide black streak
Yes, you have a burned out scanner block element. It's cheaper to buy a new fax machine
Mar 30, 2010 | Brother BRTPPF4750E...
I'm getting a color line going down the page on my pictures and the quality of the picture is no good
IssueWhen you copy, fax, or scan an original, the resulting output contains vertical bands, lines, or streaks in one or more colors.When you print the original, the output is normal. Figure 1: Sample output with vertical white or black linesc01892760.gif Figure 2: Sample output with vertical colored bands or linesc01892761.gif
NOTE: This article does not apply to most PSC products, to the Photosmart C6100 or C7200 series, or to the Photosmart Premium C309a and C309c All-in-Ones.If you are using a PSC product other than the PSC 2400 or 2500 series All-in-Ones, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01887564) (in English).If you are using a Photosmart Premium C6100 or C7200 series All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c00899181) (in English). If you are using a Photosmart Premium C309a or C309c All-in-One, go to Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans (c01622189) (in English). Solution one: Reset the All-in-One If there is static interference, or loose connections with the product, this can result in bands or lines in the copy, fax, or scan output. To resolve this issue, check the product connections and reset the product.
  1. Make sure the product is powered on, and then disconnect the power cord from the product.
  2. Disconnect the USB cable from the product, and then disconnect it from the computer.
  3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
  4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
  5. Reconnect the power cord to the product.
  6. Press the Power button (c01892763.gif ) to turn on the product.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , see the next solution.
Solution two: Clean the All-in-One and print a blank copy If the scanner glass or the white underside of the lid has fingerprints, smudges, lint, dust, or other debris, this can slow performance and affect copy and scan quality. To resolve this issue, clean the All-in-One. Before you begin, gather the following materials:
  • Several clean, soft, lint-free cloths
  • Mild glass cleaner
Step one: Clean the scanner glass and lid
  1. Press the Power button (c01892763.gif ) to turn off the product, and then disconnect the power cord from the product.
  2. Open the scanner lid. Figure 3: Open the scanner lidc01893292.gif
  3. Spray a clean, soft, lint-free cloth with mild glass cleaner.
  4. Wipe the scanner glass and the white underside of the scanner lid with the dampened cloth. Figure 4: Scanner glassc01893293.gif Figure 5: Scanner lidc01893294.gif
  5. Dry the scanner glass thoroughly with a clean, dry cloth, or chamois to prevent spotting, and then dry the white underside of the scanner lid.
  6. Close the scanner lid.
  7. Reconnect the power cord to the back of the product, and then press the Power or Start button (c01892763.gif ) to turn on the product.
Step two: Make a blank copy
  1. Remove any originals from the scanner glass.
  2. Load plain white paper in the input tray.
  3. Press Start Copy Black to make a blank copy.
If the copy is clean, there is no need to continue troubleshooting.If the copy has vertical bands, lines, or streaks, there might be dust inside the product, poor internal connections, or the product might be damaged. See the next solution. Solution three: Service the All-in-One If you have completed all the steps listed above and are still experiencing a problem, service the product. Causes
  • Static interference
  • Loose USB cable or power cord connection
  • Fingerprints, smudges, lint, or dust on the scanner glass
  • Dirt or debris on the scanner lid
  • Scratched or damaged scanner glass
  • Poor internal connections
  • Dirt or debris inside the product
  • Damaged or faulty scanner bulb or parts
Jan 27, 2010 | HP Photosmart 2610 All-In-One InkJet...
White vertical streak
what type of projector is it? what model?
Oct 22, 2009 | InFocus Office Equipment & Supplies
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Magenta leaving a colorless streak
You need to check with Xerox , ther is some toner that was manufactured last year (2008) that was defective
the phone number for xerox support is 503-682-7377
Apr 01, 2009 | Xerox Phaser 7760/GX Laser Printer
Streaky copies
It probably has several issues - optics dirty, and drum, and blade failing. I would also imagine that even the Solid "blacks" aren't as black as they could be, and that would be the developer. This machine is in the 17 year old range, and I wouldn't spend dime on it
Mar 29, 2009 | Ricoh Office Equipment & Supplies
Vertical Stripes on printed Page, Shaken Toner, Relatively new Belt (Green thing), cleaned the fuzer wire, cleaned the cleaner roller, has oil.
Depending on the type and model of your printer this could be several things mostly related to the cartridge or drum if you have a separate toner/drum system.. Since you have stated you have shaken the toner, I am assuming you have a laser printer. New belt, has me confused. Green thing leads me to think you are talking about the drum. If so, did you purchase a new toner cartridge or new drum cartridge?
Several components inside the toner or drum cartridge will cause vertical streaks. It depends on where these streaks are occurring and how wide the streaks are. We call these repetitive defects and they can be measured to determine which part is at fault.
Also, if this is a multi-unit machine (print/copy/fax/scan) Check the platen glass or ADf feed unit for white out. That has been a major culprit of vertical streaks on the page.
More specifics about the model of machine and cartridges being used would be helpful in trying to solve this problem for you.
Nov 14, 2008 | Brother Office Equipment & Supplies
Pale, unreadable print
Make a copy and stop it in the middle of the procedure...take out your drum unit and check if all the image is there(on the drum and on your sheet)....if so, put everything back in position and make another copy and this time stop it just before it goes out....if you see your white line there you might have a fuser problem !
Mar 27, 2008 | Epson Aculaser C1100 Printer
LONG WHITE VERTICAL LINES
It sounds like the drum may need to be replaced. The streaks may be caused by sections of the drum no longer being able to hold a charge and therefore, toner will not properly stick to the paper in those sections and you'll be left with long white streaks on the paper. This is a usual symptom of a bad drum.
Jan 13, 2008 | Sharp AL-1000 Laser Printer
Toshiba e-Studio162D Copier Logo
167 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
