Question about LG LD-1420T1 Dishwasher
Shortly after cycle starts, a whirring sound starts, is this a problem with the motor?
Posted by holly_hager on
Carl Schulzetenberg
  • 1,543 Answers
With LG dishwashers: after starting, 1st, DW pumps out any remaining water, 2nd, DW fill fresh water, 3rd, main wash motor starts, which is normally a whirring sound. (If you here grinding or rattling, then you have a problem.)
Posted on Feb 28, 2011
Machine stopped and bells rang
It sounds like the water pump has seized judging from the noise that you were hearing.
When the water seals become old and worn, water seeps through and ends up in the pump motor bearings, which corrode and eventually fail.
Open the machine up and check the pump, they are not repairable, will have to be replaced should this be the case.
Feb 08, 2016 | LG Dishwashers
Whirlpool AWG 349/3 1200 won't start a cycle
sounds like a motor burned out. either the main motor or the pump. and if you can't get it out, you may have to get someone to get it out and work on it for you. doubt it's an easy fix. sorry.
Nov 08, 2013 | Whirlpool Washing Machines
Ford Ka starter motor won't start but makes whirring sound. It usually takes 3 turns of the iginition to start
Sounds like the solenoid is bad on the starter..Starter probably needs replacing.
Feb 23, 2013 | Cars & Trucks
Lg dishwasher noise
This is very bizarre. Very likely the debris you found could have caused some damage to the dishwasher parts. If you have taken photos of the experience may be a good idea to send to the manufacturer and ask them to replace the affected parts without cost to you. This is the least they should do.
Dec 31, 2012 | LG Dishwashers
Car would not start so i replaced starter motor.still wont start
Check power levels and then try and jump it. If nothing you may have a short thats some that is hard to trace back check all point of contact all the way to spark plugs make sure you are getting firer to the plugs. You may have to take it in. Now make sure the new starter is in line properly
Sep 11, 2012 | Cars & Trucks
F&P GW712 stopped on rinse cycle and motor made whirring sound. After stopping and starting it water finally out. Sounded sick.
The pumps on F&P washers are known to make whirring, and screeching noises. It could mean that the pump is failing and that it should be changed.
It is not a big job, and takes very little time, as long as the machine has been emptied before the job is started.
Probably best to call a tech, because he/she can check for blockage and also check the pump motor 'resistance', which is reccomended by F&P.
TECH TIP To remove the pump motor, lean the machine back against the wall and study the pump and the 'latch' which secures it. Remove double wires, rotate the pump motor anticlockwise, 'unlatch' and comlete the removal. Disconnect the earth wire.
Replace the pump in reverse order...
Good luck....Nomess
Sep 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
Dishwasher fills, when the pump is supposed to start it just whir
Hello, sounds like a broken wash impeller or a stripped drive impeller (the piece that fits inside the impeller). These two parts are driven by the wash motor and propell the water through the spray arms. good luck
Dec 27, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Whirring noise in spin cycle, 7 year old machine
Checking the pump woulb be the first step. The pump bearing get worn and begin to sqeal. If the pump is alright then the problem could be the spin bearing.
Oct 19, 2007 | Maytag Performa PAV2200
LG LD-1420T1 Dishwasher Logo
455 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Bill Johnson
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
