Question about SVP CDC-8630 Digital Camera
Nothing appears on the screen after i put the camera on and same time cannot be put off.
Posted by dasamoah73 on
  • Anonymous Feb 28, 2011
    Are you running windows? If so what version?
    Does the camera save pictures to memory? Are you saying that just the lcd is not working? Does the lens attempt to focus or does just the light come on?
Andre
    New Friend:
    Problem Solver:
  • 12 Answers
Try taking out the battery, putting it back in then resetting the camera.
Posted on Feb 28, 2011
Hi! i have a cannon ixus digital camera. It got wet about a year ago when i was at the beach, now the problem is every things okay except when i capture a photo nothing appears on the screen no image at...
Try and press the display button (on Ixus a square with a right pointing arrow) several times to see if your images appear at any time.
Your problem may be as simple as inadvertenly pressing this button into the off mode.
If that does not work, try to recharge your battery, reinsert it and turn the camera on again to test your LCD screen.
Since you haven't descibed any error codes coming up on your camera, I suppose it isn't that bad.
If this does not help you may have to get your camera repaired.
Good luck
Jun 28, 2011 | Cameras
Where can I download an instruction manual for a Fuji A204 digital camera please
I recently bought a fujifilm digital camera an when i turn on the power it appears to have a blank white screen, an nothing else seems to work ive tried pushing the menu botton an switched it on an off many of times, but nothing seems to be working just a blank white screen please coul d you help me thanks,.
May 01, 2011 | Fuji FinePix A204 Digital Camera
E1235 - nothing appearing on screen/can't photo view
Ok, I just solved this issue. I have had the issue for a while and called GE and they told me they would give me a discount replacement at $125, when new it is less then $100. SO GE ITS NOT HAPPENING!!! Well I decided to fix it my self.
1st: Take out all the screws (7 total) one is hidden under the av out cover. Make sure u mark all the longer screw heads and location with a marker so you know where they go. There were only to sizes so if you mark the longer ones you should be ok.
2nd slowly pull the back of the camera back (BUT BE CAREFULL, do not pull to far there are wires from the LCD and buttons to the camera.) Now there is a little tab on the main board holding the wires from the LCD to the camera. Flip it up and remove the LCD wires. After you do that push the LCD wires back in and flip the tab back down. Be careful not to damage wires or tab. Put case back together, put screws in where they go, and wallah. Your camera should work. If not try again, and make sure your properly putting wires in. If it doesn't work email me I will be making YouTube video for this soon. REMEMBER TRY AT YOUR OWN RISK!!! I AM NOT RESPONSABLE FOR ANY DAMAGE YOU CAUSE!!!
Apr 17, 2010 | General Electric GE E1235 Digital Camera
Camera is not showing up on computer
try connecting and disconnecting a few times then blow on the battery hole and reinsert them
Oct 25, 2009 | Olympus FE-370 Digital Camera
"Format the card" appears in the screen and I can do nothing! "Format" or "Full Format", but nothing helps
Have you actually tried to format the card in the camera and you still get these messages?
Aug 14, 2009 | Sanyo Xacti S5 Digital Camera
How do i remove the date , time, 101nikon 1939 jpg on top of the
This will always be displayed in your camera. However to choose what will imprint on the pix :
Turn your dial to SETUP and select DATE IMPRINT. Then select OFF (nothing will imprint on pix), or DATE (for just the date to be imprinted), or DATE and TIME (for both time and date to be imprinted)
May 15, 2009 | Nikon Coolpix 4200 Digital Camera
Sony DSC W40 , screen appearing black
ther should be a small button below the menu botton try pressing this a few times this a energy saving device .hope this helps.
Dec 04, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Nothing but a blue screen...ugh!
buy a cleaning cassette and play three times it will work well.
Oct 12, 2008 | JVC COMPACT VHS-C CAMCORDER
Samsung s860 digital camera turns on and then goes to blank screen and will do nothing else, to turn off it requires battery removal. same story with new batteries.
Dear customer
thanks for ur inquiry for ur product
If the LCD screen is blank or black when you have your camera in the Camera or Play mode, the camera may need service. To determine if this is the case, follow these steps:
1. Press the Menu button to see if the LCD screen can display the OSD (On Screen Display). 2. Set your camera to Play mode, and then see if the LCD screen displays a picture. 3. To eliminate the possibility of a user setting causing the problem, put the unit into Auto mode by rotating the dial on the units exterior to Auto Mode. Note: The word "Auto" appears on the screen when this mode is activated. 4. If putting the camera into Auto mode does not resolve the problem, test the unit in Play mode. If the unit operates normally in Play mode, but the screen in Camera mode is blank, your camera requires service which you can arrange by Creating a Service Ticket below. Note: Because your camera has an automatic LCD display shutdown feature, its normal for the LCD to stop displaying when the camera has been on for along period of time. This feature prolongs battery life.
urs sincerely
Harrish
Jul 10, 2008 | Samsung Cameras
SVP CDC-8630 Digital Camera Logo
29 people viewed this question
Top SVP Cameras Experts
Marvin
Marvin
Harrie
Are you a SVP Camera Expert? Answer questions, earn points and help others
