If nothing else works, the washer door can be opened as follows: •This must only be done in an emergency if the machine's glass door does not open automatically when the program has finished. •First check that there is no water left in the machine. If there is water left in the machine and it is not possible to run the Drain program, empty the machine by using the drain hose. •Make sure that the main power switch is off and that the plug has been re- moved from the wall socket. •You will find the emergency opener for the glass door in the double sealed bag. •Open the glass door by putting the opener in the slot to the right of the lock on the door. Push the opener up or down and the door will open.
