If your machine has 2 water hoses connected check to see if both water valves are connected, if so the you have a faulty cold water valve. If you have only 1 water hose then the cold water valve on the twin or triple valve is faulty. You can change these easily buy removing the top panel and removing the valve, usually only 2 screws. Hope this helps.
Testimonial: "omg thank you that makes so much sence, you are amazing tytytytytytyty!"
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
