Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I need connect a wirelees router a this modem,u help me plzzz
Posted by rosaescorpio on
hlondono
  • 31 Answers
Connect an Ethernet cable from your RCA Cable Modem to your Wireless Router into the WAN port.
To setup your Wireless router connect to your computer to your Wireless router using another Ethernet cable into the LAN port then Open Internet Explorer and type 192.168.1.1 to access the Wireless router configuration page. Under Login: Type in the login name (Typically the default login = admin pass = admin, check your Wireless Router manual) Then Click Login and go to Wireless.
Posted on Feb 28, 2011
iosuan
    New Friend:
  • 32 Answers
Most wireless routers are setup for cable modems out of the box all you need to do is run an Ethernet cable from your modem to your wireless router. you can then access your wireless router by the ip address and a pc hooked you directly to the router.
Linksys WAG54G-UK Router Blocker
Hello I have a question wirelees have a network connection at a hotspot romtelecom a router without antenna which is called LINKSYS NETWORK IS FREE WIRELEES How can I find the IP address of your router linksys As I have access to it Thanks
Jan 14, 2013 | Linksys WAG54G-UK Router
My internet connection never runs constantly. i always get disconnected after using it for a minute or two and then my router again tries to establish a internet connection.after the connection has been...
1. Disconnect the router from the modem.
2. Reset the modem.
3. Connect your computer directly on the modem.
4. Check if the wired connection is OK (for longer time).
5. If not, check/replace the filter splitter, if you have one.
6. If still having problems: Call your ISP to check your status.
7. When the problem is solved, connect the router to the modem.
8. Reset both router and modem.
9. Recheck the connection.
Aug 13, 2011 | Linksys Wireless-G Broadband Router
When i enter chat rooms in yahoo , it says to me :you not authorized to enter the confrence, help me plzzz
To test if it is your profile or the router. Try connecting your computer directly to the modem and see if you can access those rooms. Log in using a different computer. It could be ports that re blocked if you do not access to any of the rooms.
Jul 01, 2011 | Computers & Internet
Hi. i have the zyxel P-600 series. i have it connected to my desktop and i am able to go on the Internet using my desktop. i used to be able to go on the Internet using my laptop as there is wireless....
you need to check if you have the wirelees hot spot enabled
do it following the next steps
1- Press the WPS button on the nbg-417n, you should see that the wlan led blinks 2- Check that your wirelees adapter is enabled in your lap
then it should connect to the net
if you still have issues check the next document http://www.zyxel.co.uk/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420081028103616
Mar 22, 2011 | Zyxel NBG-417N Wireless Router
Hi, my linksys wirelee-g-wrt54g. can no see the internet, what kind of test can I do in order to see if it cab be fixed
This could be a problem with your service provider's router/modem.
Can you connect directly to it via ethernet cable?
Dec 06, 2010 | Linksys Wireless-G WRT54G Router
Looking to hook up wirelees router
You should have one plug that is marked WAN - this connects to your modem with a standard Ethernet cable. If you cannot read the labels, it will be the plug, slightly removed from the other four plugs.
You need to connect the power adapter to a power strip to avoid unnecessary power entering your network and to protect the router.
You should be able to start the router without a PC attached. Just look for Dynex being broadcast wirelessly. Your network is not secure wirelessly until you add a password to the network.
See if you can get to fixya.com from your laptop. If so, things are going pretty well. You now want to add security to the wireless network.
Write back if you need help.
May 24, 2010 | Dynex 4-Port Ethernet Broadband Router...
Can't find security key
the wep/security key on 2 wire modems is located below the serial number label on the side of the modem.
Sep 25, 2009 | 2wire 2700HG-B Router (2700HGB)
How can i use as a second router to expand my
connect every wireles router to a modem with more output posibilitys ore conect to output from first wireles modem so you can chooce witch wireles modem wil connect to the laptop or pc
Aug 22, 2009 | Zyxel Prestige 600WH Wireless Router...
Hard ware problems
HI Barry
You need something called an ethernet cable. One end of the cable goes in the router and the other end goes in the ethernet poet of the computer.
This is an ethernet cable
512c92e.jpg.
This is the network port (ethernet) of the PC
If you dont have an ethernet port on ur pc u may need to pay an ethernet pci card like this and get it installed on your computer
Hope this helps
Cheers
JigSaw
XoXo
Aug 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
588 people viewed this question
Top RCA Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
