Canon MultiPASS F50 All-In-One InkJet Printer Logo
Posted on Feb 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Canon F50 printer and it is not printing correctly. It misses lines on the copies. I have put in a new Canon cartridge but it continues to do so. It keeps saying it is out of ink, but the new cartiridge is in there. Thank you in advance for any suggestions.
rfredey
Level 2:
Habit-Forming:
  • Expert 145 Answers
  • Posted on Feb 02, 2018
rfredey
Expert
Level 2:
Habit-Forming:
Answers
145
Questions
Helped
27810
Points
491
First question is whether it is a valid Canon cartridge. If it is you may need a new print head. Try putting in the old cartridge (suggest you shake it a little first) and see if that changes anything.
Moss'es Chauke
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 7 Answers
Moss'es Chauke
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
7
Questions
Helped
768
Points
15
Hi wet a cloth with hot water and take out your cartridge whipe the cartridge with the cloth on ink sude,when finished take a white paper and whipe it dry,when u see all colours on the paper you'll know your cartridge is ready to be used.
W.L.
Level 3:
  • Master 2,511 Answers
  • Posted on Feb 28, 2011
W.L.
Master
Level 3:
Answers
2511
Questions
Helped
524257
Points
8345
Use the canon utility and run a cleaning cycle.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
My Pixma MG5250 has run out of Cyan ink, how can i continue to print with just black ink?
With the canon single ink inkjet printers it is not possible to use only the black cartridges for printing. You will have to put a new cyan cartridge into the printer to continue printing.
Changed ink cartridges, error code Wrong Cartridge, won't print, copy or scan
I had this same problem with my HP All in One. They told me the cartridge was defective, or the sensor was bad. Try a new cartridge first.
Printer/copier has been idle for about 3 years as we were out of the country. Now I cannot get it to copy documents
If it goes through all the motions like its making a copy but the page is blank you need a new print head or cradle with new ink cartridges. Ink printer do not like to sit for long periods. It will cost about 60.00 from canon. Steven 818-888-0006
2helpful
Canon MP F50 "wrong cartridge" error
remove all cartridges leaving printhead intact.
close cover, turn off
turn on, let power up, error message should be gone.
open cover, reinstall cartridges
if you cleaned your print head like I did you'll probly
eventually end up getting a new one anyway, due to the color variations
but I can at least print text.
2helpful
While printing photos my printer has white vertical lines
Sounds like you need to re-align the print cartridge . The reason the text comes out ok is probably because it is only using the black cartridge for text. The color cartridge is the one that's out of alignment. You may have some sort of Cannon utility running in the task bar that will allow you to easily allign the print cartridges. If not, go to the main "Printers and Faxes" window, RIGHT-click on the printer and select "Properties". You should be able to find a button in the properties that's labeled something like re-align print cartridges. It will print out a series of test pages and ask you to select the set of lines that looks the straightest and type it in. It's a good idea to do this every time you replace a cartrige. Hope this helps, If I was able to FixYa, please remember to rate me. Thanks.
1helpful
Canon Multipass F30 not printing
Did you remove the tab that covers the cartridge head where the ink comes out, if the drivers and software that you loaded on your pc work
good and your printer shows under device MGR, then it is the printer
itself,,most times you can not see how much ink in the cart,,,most are sealed,,,just try to put the cart in again and make sure it is locked in good,,try running the cleaning program with pc,,make sure the right
cart is in the right spot, bl in one spot and color in a spot.
2answers
Wrong cartridge messsage
Hi, Please follow :
1. Reseat F30 / F50 print head 2. The Print Head may need replacing - F50 3. Press ON/OFF switch to reset the multifunction device 4. The F50 may require repair
You can see exactly how to perform these steps with pictures at this link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=6324
Go to this link if you are unable to find the"Wrong Catridge" link
then you need to type "wrong cartridge " in the small search box on the website.
If the website asks you to select
"Category.=Multifunction"
"Product Type =Inkjet"
"Model= Multipass F50"
Cheers
4answers
Wrong Cartridge Error Message
I have same problem.Please let me know if u find an anser
The Print Head might be the fault of that,try replacing the print head and see if that helps
old marine
old marine
ZJ Limited
ZJ Limited
