Here's the codes to your sharp tv for that remote
Sharp TV:
013, 028, 035, 073, 075, 078, 092, 093, 120, 131, 132, 134, 139, 141
1. T urn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device. (just try one of the codes I listed above) if one doesn't work just try the next one,
3. Press and hold the corresponding button on the remote control(TV,
VCR, SAT, DVD, CAB or AUD) for approximately three seconds. The POWER
INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press the POWER button to verify correct code entry. If the device
shuts off, the code was entered correctly. If the device does not shut
off, repeat steps 3-4, using a different code.
001 029 033 045
048 049 052 091 139 141
157 162 214
OK.
Manual Programming
1. Turn on the device with which you
device. Refer to the the below codes
button on the remote control (TV, VCR, SAT, DVD, CAB or AUD) for approximately
three seconds. The POWER INDICATOR illuminates.
5. Press to verify correct code entry.
If the device shuts off, the code was entered correctly. If the device does not
shut off, repeat steps 3-4, using a different code located below
Sony
002, 018, 026, 098, 100, 121, 123, 134
