Question about Samsung ML 2525 BW laser Printer
I own a ML-2525/XAA and have a blinking light on the right hand side of the unit. It looks like: <--->/(a triangle with an explanation mark inside it.
Posted by jecon7373 on
JaksLax
    New Friend:
  • 11 Answers
Per your user manual, here is a list of all the LED status':
Jam (I own a ML-2525/XAA and - b-error.png)
Orange
On
A paper jam has occurred. (See Clearing paper jams.)
Online/Error (b-online.png)
Off
  • The machine is off-line.
Green
On
  • The machine is in power saver mode.
  • The machine is on-line and can receive data from the computer.
Blinking
  • When the LED slowly bilnks, the machine is receiving data from the computer.
  • When the LED rapidly blinks, the machine is printing data.
Red
On
  • The cover is opened. Close the cover.
  • There is no paper in the tray. Load paper in the tray.
  • The machine has stopped due to a major error.
  • Your system has some problems. If this problem occurs, contact your service representative.
  • A toner cartridge has almost reached its estimated cartridge life[a]. It is recommended to replace the toner cartridge. (SeeReplacing the toner cartridge.)
Blinking
  • A minor error has occurred and the machine is waiting for the error to be cleared. When the problem is cleared, the machine resumes.
  • Small amount of toner is left in the cartridge. The estimated cartridge life[a] of toner is close. Prepare a new cartridge for replacement. You may temporarily increase the printing quality by redistributing the toner. (See Redistributing toner.)
Posted on Feb 28, 2011
Franky Pierre
    New Friend:
  • 14 Answers
Sometimes that means there is a paper jam. I would try taking out the laser cartrigdge and looking for paper that is stuck in the printer. You have have to open the rear door or remove the paper tray to find it.
Timer blinking
Turning the record timer on/off
  1. 1 Press TIMER/CLOCK ADJ.
  2. 2 Use the <> (cursor left/right)
buttons to select REC.
On the front panel use '<<>> and <<>>'
  1. 3 Press ENTER.
  2. 4 Use the <>(cursor left/right)
buttons to select ON or OFF.
5Press ENTER.
Apr 20, 2014 | Pioneer XVDV830/SDV830 DVD AUDIO HTP...
One side of copy is smudged with too much toner, while the right side is faded and too light to read.
100% the problem contains in toner cartridge. If the toner is refilled, probably there is a problem with "doctor blade" of the cartridge. Try to clean it very carefully, because maybe there is a "crystalized toner " on the blade.
Pifonski
Nov 04, 2013 | Samsung ML 2525 BW laser Printer
Samsung ml 1666 usb printer sleeping problem
Looking beautiful. Thanks for sharing with us.<br />Please visit on these keywords :-- <b><a href="http://howtofixdelllaptop.blogspot.com/" rel="dofollow">How To Fix Dell Laptop</a></b>
Oct 20, 2012 | Samsung Office Equipment & Supplies
Canon 50d error 50
Go to the Canon web site and look at the list of error codes for an explanation. Or Google Canon Error Codes
May 30, 2012 | Canon EOS 50D 15.1MP Digital SLR Camera...
My Dell 1130 Laser Printer has a red light flashing (triangle and &lt;--&gt; symbol). What does this mean?
Your toner chip page counter has to be reached on last point (run out). Normally one OEM toner cartridge chip can print 2.5k pages, after that cartridge has been locked (although it's remain toner) and red light will be blinking. So, you can't able to take print furthermore in this state. You need to change cartridge chip or you can contact me by my mobile: +91 9330033560 or write a mail to my email id: <[email protected]> I have a solution for changing printer firmware which will make you printer permanent solution for taking print out without changing chip.
Feb 01, 2011 | Dell 1130 Laser Printer
Need instructions for t436b night light
Here is a link to the manual.
http://www.timexaudio.com/pdf/T436_IB_(new)_v3b40949_96.pdf
From the manual here is how to set the time.
2. Press and hold the Time Set Button until the time display blinks.
3. Press the << or >> Button to adjust to the correct time. Press and hold the button for faster forward or backward
adjustment.
4. Remember to set the correct AM or PM. The PM Indicator is located on the upper right side of the display;
there is no AM indicator
5. Press the Time Set Button again. The year display will blink.
6. Press the << or >> Button to adjust to the correct year. Press and hold the button for faster forward or backward
adjustment.
7. Press the Time Set Button again. The date display will blink.
8. Press the << or >> Button to adjust to the correct date. Press and hold the button for faster forward or backward
adjustment
9. Press the Time Set Button again or wait for about 10 seconds to exit the time setting process. Two beeps
will confirm time setting mode is complete.
Sep 08, 2009 | Timex T311T Clock Radio
Toner exhausted
open the back cover and locate the chip numbered 93c66,its above the USB port on the mainboard.short the top-left and bottom left pins and turn the printer on for 5-10 secs...that resets the page count to 0... also either remove the chip on the toner or cover it with a cellotape
Sep 01, 2009 | Samsung SCX-4300 Monochrome Laser...
Samsung ML 2525   BW  laser Printer Logo
1,178 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
