Fisher and Paykel GWL11 Top Load Washer Logo
Posted on Feb 28, 2011
Washing is squealing during filling process??
Matt Householder
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Jun 22, 2011
Matt Householder
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
4401
Points
15
I found that my squeal was coming from the little rubber boot that seals the pump from the impeller.
I silenced the squeal as follows...
Give it a try. It might work for you, too. It takes about 30 minutes.
  1. Unplug the washer.
  2. Pull it away from the wall a foot or two.
  3. Tip the washer back toward the wall.
  4. Have a strong, reliable helper hold the washer in that position -- firmly against the wall.
  5. Get down on the floor. Lie on your back and put your head and arm under the washer (that's why you need a good helper!).
  6. Unplug the electrical wiring to the pump. (The GWL11 has 2 wiring connectors.)
  7. Slide a shallow plastic dishpan under the pump to catch any water.
  8. Find and bend back slightly (don't break it!) the plastic retaining latch that holds the pump in place.
  9. Rotate the pump counter-clockwise about 60 degrees, until it comes free.
  10. Note the angle/position of the pump as you pull it free. This is the same angle/position you'll need when you put it back in, of course.
  11. Get out from under the washer -- with the pump, of course.
  12. Have your helper lower the washer to the floor.
  13. Have your helper clean up any excess water that runs onto the floor.
  14. Put the pump on a well-lit table or other surface covered with newspaper.
  15. Using a straight blade screwdriver, pry directly underneath the plastic fan (right up against the shaft) to carefully and slowly work it off. Don't lose the small plastic fan bushing!! - which is actually what you are prying against. Also, as you remove the fan and bushing from the shaft, note carefully how the bushing fits on the shaft. There is a right way and a wrong way to put it back!
  16. Now, you are ready to remove the motor/shaft/impeller assembly from the bearings/windings assembly. But first!! Find on the white plastic impeller frame the locking tab that was engaged with the latch in step 8 above - and put a piece of tape on the black bearing/windings assembly to mark the tab's position for reassembly.
  17. Using a 7mm socket (or end) wrench, remove the 2 bolts holding the impeller/shaft assembly to the bearings/windings assembly.
  18. Carefully pull the impeller/shaft assembly from the bearings/windings.
  19. Spray the bearings with a high-quality silicone lubricant. Buy a small can. It is worth it. Do not use WD-40 or 3-in-1 Oil!
  20. Using toothpicks, Q-tips, and paper towels, clean any dust, dirt, and hair from the bearings.
  21. Spray the impeller shaft and rubber boot inside the white plastic framework with silicone lubricant.
  22. Using toothpicks and bits of paper towel, clean the shaft around the boot. Move the shaft back and forth a few millimeters to compact the dusty, hairy crud - so you can spear it with a toothpick and pull it away. Using a toothpick, stuff a shred of paper towel inside the white plastic framework and rotate the shaft. Remove the dirty paper towel shred. Spray more silicone onto shaft and boot. Repeat this cleaning process until paper towel comes out clean. It is a little like building a ship in a bottle - but quite doable.
  23. Once everything is clean as a whistle, put a spritz of silicone lubricant in each sleeve bearing and on the impeller shaft near the rubber boot.
  24. Re-assemble everything in the reverse order starting with step 18 above.
  25. Test out your fix with your helper and...
  26. If no squeal, bask in the glow of gratitude and self-confidence!
  27. If it still squeals, order a new pump.
BTW - Cleaning all dust out from under the washer a couple times a year should help prevent pump squealing in the future.
Noisy and wont agitate during wash cycle. will spin and drain.
the strap (belt) is chipped, damaged, the spindle from the VAT ruptured, cracked the tank squealing stops, etc. more details please
I have a Fisher Paykel Model GWL11. It is squealing very loudly during the fill cycles. I am afraid the water pump is going out?? Any ideas?
Hi Chris2483,
I have come across this before. It is the water inlet valves. Replace these and your all set.
Washing machine makes squealing noise during the
when belt was changed did you find the old belt to be oiley . it maybe leaking oil from trans . and the belt will keep failing till oil leak is corrected.. mm
LG f1256qd front loading washing machine, during fill up it makes a high pitch squealing
Sounds like too high water pressure, could also be dirt in fill valve / faulty valve. Good luck
During fill up, machine makes a high pitch squeal
Have you checked your hoses for a leak? We could pin point which hose was leaking by trying all cold, then all hot...although changing both at the same time and on a routine basis is a great idea.
Squealing when filling.
there is a loose washer in the valve and the water is gong behind the washer therfore makeing the sound,, change the shut off valve and you will no longer have a sound,, good luck,, and make sure you trun off your waer to your house before removing the valves
During washing the kenmore 70 series washer squeals
Re-check the motor coupler.
If it was not seated flush on both post it will bind and squeal.
2answers
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
