Question about Akai LCT2060 Television
AKAI LCT 2060 was working well as a TV. Just hooked it up to my PC and the message on screen reads "No Signal" Checked monitor cable and it's good. checked old monitor and it works well. Why doesn't LCT 2060 work as a PC monitor when cable plugged in? Jim
Posted by jmchurch on
Sebastian Hooker
    New Friend:
  • 153 Answers
The display settings on your computer need to be turned down. Set it to 800x600 and move up from there, if the resolution is too high - the TV won't display it.
Posted on Feb 28, 2011
Akai LCT 2060 TV will not turn on. Power unit shows blinking green light, but no picture.
Click HERE to download service manual copy as it was promised in chat session.
Thanks.
Jan 07, 2011 | Akai LCT2060 Television
Faulty monitor ctx pv720a. The screen has the
Try another cable, or check the plug for bent pins. If they are all good, check that the monitor is set for VGA input (if it supports VGA and DVI) as it may be looking for a different input. Then replace the monitor. It's not common, but video processing circuitry can sometimes fail, and yours may have. New 17-inch LCD monitors are quite inexpensive now, so it would probably be more economical to replace this one than to try repairing it.
Jan 01, 2011 | CTX PV 720 17" LCD Monitor
MY PC DOES NOT HAVE A HDMI PORT CAN I USE MY PC MONITOR CONNECTION CABLE TO CONNECT TO MY AKAI LCT3285TA 32 PLASM [THERE IS A PORT ON THE BACK OF THE TV BUT I GET NO SIGNAL...DO I NEED TO MAKE SETTING...
Look at the function keys (F1 to F12) in your computer since there is a shortcut key in it. Look for a key with an icon resembling like a TV and a PC Screen with a slash. It's like TV/Monitor icon.
Now with the PC (laptop?) hooked with the TV, (the tv showing no signal), hold down the FN key and press that function key with the TV/Monitor icon.
Jun 04, 2010 | Computers & Internet
I have a AKAI LCT 2060 TV, cannot see picture, only sound
This problems,i fix alot models of tvs all diffrent models of tvs but have the same board alway dies.The LCD inverter board is dead.This board help the LCD to have a backlight to go through the Turner board to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.The board is long in shape.It the easiest board to replaced in LCD tvs.
May 07, 2010 | Akai LCT2060 Television
AKAI 27 Model #LCT2785TA
The message you are seeing means that the tv is not receiving a signal from the source. Try hooking up a different source such as a DVD player or a Cable Box to that same input on the tv. If you have picture and sound then the problem is with the original source. If that does not work then you have a bad Main bd.
Jul 10, 2009 | Televison & Video
No signal
This problem requires you to test both the monitor and the signal input form you cable tv setup. Set the monitor up on a computer and see if it works properly. If it does then you may have a problem with the signal conversion of the cable tv to the monitor. It also could be a weak signal that drops below the monitors sensitivity levels. Have your cable tv repairman check the signal levels on your lines. Another way to test this is to hook up is with a different monitor to test your setup and see if it works. If after testing you find, the monitor does not work properly, then you need to have it serviced. Hope This Helps.
Mar 12, 2009 | Envision 19" Widescreen Flat Panel LCD...
Hi there, my viewsonic monitor VX912 is not getting a signal from my computer. I first checked to see if the connections were good. No joy ther! so I then tried to see if the cable was faulty(my monitor...
Is your tv HD, it may have worked on the digital signal, but perhaps it switched to a HD program, and it doesnot support that HD signal, If not it may be a switching problem
Dec 16, 2008 | Evesham Computers & Internet
NEED AN OWNERS MANUAL FOR AKAI LCT2060 My Tv.not have power
hola nesecito el modelo del boar el tv es akai lct 2060
Jun 07, 2008 | Akai LCT2060 Television
Akai LCT2060 Television Logo
111 people viewed this question
Top Akai Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
