Question about Apple iPod Photo MP3 Player
Posted on Feb 28, 2011
Turn on the ipod. Press the menu button, and scroll down to one item above the bottom of the list. This should be the settings. Press the center, or select, button. Scroll down to the third menu item from the bottom. This should now be the language option. Press the center button and select english from the list.
Source:http://support.apple.com/kb/ht1824
You should be able to use Apple's support page on this issue to be able to set the language preference back to English.
http://support.apple.com/kb/HT1824
No problem, you'll just need to do a full reset to restore the language to English.
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) 2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
