Question about Fisher Price Geotrax Remote Control Timbertown Railway Train Set
I replace the batteries in the remote control and the train will not go. Is there batteries in the train that might need to be replace, if so, where do I find them?
lordbal
    New Friend:
  • 13 Answers
According to the Instruction Manual it requires 6 AAA batteries, you will need a Phillips screwdriver to access the panel where you must replace it.
The remote controller and the engine need batteries.
Engine
• Locate the battery compartment on the back of the Engine. • Loosen the screws in the battery compartment door with a Phillips screwdriver. Lower the battery compartment door and insert three "AAA" (LR03) alkaline batteries. • Close the battery compartment door and tighten the screws with a Phillips screwdriver. Do not over-tighten. • If this product begins to operate erratically, you may need to reset the electronics. Remove the batteries and replace them in the toy.
Posted on Feb 28, 2011
Hi I have a Rio Grande Train set that I bought for my son. The train works but is not responding or working when we use the remote . Ive out brand new batteries in the remote the light comes on when we...
Look for a small opening with little white tabs that can be moved up and down, on both the train and the remote. All the tabs must be in the same position. ( Same thing on a garage door opener.)
If that's not it, make sure the batteries are in correctly in both items, reversed batteries will run lites and such, but not remote controls.
Nov 22, 2013 | Scientific Toys North Pole Express Xmas...
Lionel battery operated g scale locomotive will not move
Replace all batteries in locomotive & remote.
You do need to be fairly close to the set with the
remote for it to work.
Jan 19, 2013 | Lionel A Christmas Story Gauge Train Set...
Playmobil RC Train set 4018 - have replaced all batteries but the charger wont work. It won't power the train - remote working fine. Don't know what else to do.
Clean the terminals in the remote and at the end of the battery,also inside the battery compartments that holds the battery in the charger and the the train itself. i hadn't used ours for 10 years and hadn't realised that we had left the battery in the train and the 9v battery in the handset. Tried charging it and nothing, but once i had cleaned all terminals of the green residue that had built up, it charged fine and the train ran for 45 mins before needing a recharge.
Oct 29, 2010 | Playmobil Train Station
I need a brio remote control. Can I buy one ?
Click on this link below and contact Brio for a replacement remote control to your express train
http://brio.knex.com/AboutBrio/Contact_Information.php
Aug 13, 2010 | Brio Remote Control Express Train
Remote control train won't work
The wires will have pulled off the circuit board inside.
Remove screws (force a hex driver in there) and solder wire back on.
Train surgey (geddit) is very fiddly. Have a drink first! ;-)
Dec 29, 2009 | Brio Remote Control Express Train
Brio remote control express doesn't move anymore
I wish I could help - I have exactly the same problem! Train opened Christmas Day, worked ok. Batteries seemed to gradually die 2-3 days later. Replaced all 3 sets of batteries twice, but nothing. Initially I got sounds, but nothing now.
Dec 27, 2009 | Brio Remote Control Express Train
WE are trying to get our lionel holiday train going. Is there an on/off switch on the train? the part that goes on the track is lit up but when we puch the remote control with train on the track nothing...
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
Dec 23, 2009 | Lionel Trains Holiday Express G Gauge...
Remote fell on floor, won't work replaced battery, no help
try replacing battaries, but unless you have circuit board training on how to repair broken connections i would just go get a nice universal remote and tape pillows to it so you cant break it.. .:P
http://reviews.cnet.com/best-universal-remotes/
Jun 22, 2009 | Universal Remote Control Hampton Bay...
Train makes sounds but does not move
There are bateries all over the place in this toy. two AAs in the remote, two button bateries in the tender and also two AAs in the engine, did you do the ones in the engine?
Jun 08, 2009 | Brio Remote Control Express Train
Fisher Price Geotrax Remote Control Timbertown Railway Train Set Logo
866 people viewed this question
Top Fisher Price Toys Experts
NOEL
NOEL
Marvin
Marvin
john h
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
