What are the hotkeys (keyboard shortcuts) you can use to switch for 1 port to another on a MT-201UK model, 2 port KVM Switch? Can't find the manual anywhere...
    Problem Solver:
  • 14 Answers
The hot keys which help in manual operation of MT-201UK model, please make sure that your kvm switch is compatible with USB and VGA ports
Posted on Mar 11, 2011
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 34 Answers
Try pressing your "Scroll Lock" key twice fast.
Posted on Feb 28, 2011
Cannot invoke hotkey function to switch computers .Directions say use num loc key plus minus key and release num loc but this doesnt work.
Make sure your keyboard and mouse are plugged into the correct usb slots on the switch. One is labled for keyboard, and the other for mouse. If you mix these up, those hotkeys will not work! :) Also, a much better hotkey for this switch is to tap scroll-lock twice. This automatically switches, so you don't have to hit multiple buttons.
Feb 18, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked...
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Feb 17, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
Not working
Make sure your keyboard and mouse are plugged into the right USB ports on the switch. If you plug the keyboard into the mouse USB port the hotkeys will not work! The USB ports on the KVM switch are labeled under each port, with a mouse and keyboard icon respectively.From the Quick Start Guide/Manual: The Numlock hotkeys are listed as:
[Num Lock]+[-] [1] Switches to output 1
[Num Lock]+[-] [2] Switches to output 2
[Numlock]+[-] [A] Auto-scans and chooses which ever port is connected.
Alternatively: Tap [Scroll Lock] twice to automatically switch between ports.
Note: I've never been able to get the Numlock key combinations to work correctly. I always just use double-tap [Scroll Lock] trick to switch.
If you get stuck with your scroll-lock and Alpha lock lights flashing, just hit [Esc] to fix it.
Source: http://www.aten.com/download/download.php#productGuide (Scroll down to "Quick Start Guide" and choose CS62U out of the drop down).
Oct 03, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Lost the hotkeys,Cant switch.
Found this:
http://safemanuals.com/user-guide-instructions-owner-manual/BELKIN/F1DL102P-_E
Hope it helps.
Let us know
Good Luck
Apr 13, 2009 | Belkin F1DL102P 2-port KVM Switch
NexxTech mini KVM switch - hotkey required to switch
Hit scroll lock twice quickly (within 2 seconds) then either "1" or "2" to select the input you want. I needed to remember how to do this myself today since I haven't used this KVM in years, having replaced it with a 4-port ages ago.
Feb 24, 2009 | Computers & Internet
KVM hotkey
Hold down the Scroll Lock key for several seconds. The switch should beep briefly and blink. Hit either the "1" or "2" key on your keyboard to switch to the corresponding computer connection.
Jun 23, 2008 | LinxCel PS-121D 2 Port PS2 KVM Switch
Hotkeys for D-Link DKVM-2
In my case, it is <Scroll Lock>, <Scroll Lock>, <1> or <2>
And NOT F1 or F2 as the previous writer suggests.
Good Luck,
Ludvik.
Jan 03, 2008 | D-Link DKVM-2 2 PORT KVM KEYBOARD VIDEO...
GCS5632u KVM swith working with Vista
Make sure the keyboard/mouse receiver is connected to the keyboard port on the KVM -- there is an embossed icon near each port -- mouse and keyboard.
Jan 01, 2008 | IOGear GCS632U 2-port KVM Switch
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
Dec 14, 2007 | Belkin F1DK102P 2-port KVM Switch
Computers & Internet Logo
361 people viewed this question
Ekse
Marvin
Marvin
