Sony DAV-DZ100 System Logo
Posted on Feb 28, 2011
Can i play vidio player via my sony dav-dz330
hlondono
Level 1:
  • Contributor 31 Answers
  • Posted on Feb 28, 2011
hlondono
Contributor
Level 1:
Answers
31
Questions
0
Helped
12590
Points
68
Your Sony DAV-DZ330 will play DVD video to your TV via HDMI (preferred method) or via SCART (analog video and sound) but you will not be able to connect another video player into your Sony since it does not have any video inputs.
How do I connect Sony S590 3D Blu Ray to Analog TV & Sony DAV-DX255 Home Entertainment Center
It depends what connections the TV has. If it has HDMI sockets then you should be able to connect the player via one of them. The sound should be connected using an optical lead from the player to the Sony Center.
However you will not be ever be able to play a 3D movie till you have a 3D TV. It will simply not work.
So at the moment you have purchased a an expensive 3D player which can only play back normal Blu-Ray's and DVD.
tip
Sony DAV-C700, DAV-S400, DAV-S500, DAV-S800, CMT-S9D region free unlock code
Introduction
The DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the machine.
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Sony DAV-C700
 Sony DAV-S400
 Sony DAV-S500
 Sony DAV-S800
 Sony CMT-S9D
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD MOD Upgrade disables Macrovision to solve any problems.
User manual
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [ENTER] Default Default region code on the player
[1] [ENTER] Region 1
[2] [ENTER] Region 2
[3] [ENTER] Region 3
[4] [ENTER] Region 4
[5] [ENTER] Region 5
[6] [ENTER] Region 6
[7] [ENTER] Region 7
[8] [ENTER] Region 8
[Arrow down] [ENTER] Only play DVDs with the selected region; auto switching OFF
[Arrow up] [ENTER] Default Auto switching ON
[PREV I<<] [ENTER] Enable video interference impulses (Macrovision ON)
[NEXT >>I] [ENTER] Default Disable video interference impulses (Macrovision OFF)
[Arrow left] [ENTER] Enable user operation prohibitions* and access restrictions
[Arrow right] [ENTER] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
on Mar 02, 2010 • Electronics - Others
1helpful
Hi!! I have a SONY DVD player(model- DAV DZ150K)...Recently it has refused to play DVDs (it says "cannot play this disc") and only plays VCDs and ACDs...please help!!!!
I have 1 sony DVD Model No-DAV-DZ150k .When i have select DVD mode so dest error show on VFD Disply .Pls tell me what is problem in DVD.
1helpful
Hi, i have a DAV-DZ330/DZ730 and i cant get sound from the tv/sky. TV is a bravia KDL 40NX503. Its HDMI connected and ive been through the sync process and made sure the hdmi settings are ON on the amp. No...
i had the same problem with my dz330. simply attach you sky box via scart to the back of your sony box and hey presto you should have sound when selecting tv mode from the sony remote
3helpful
1helpful
SONY HT DAV-DZ270
Hi all!!!
I am looking to play movies through USB in Sony DAV-DZ270 without looking to buy or upgrade to any other Home theater system. Is there any firmware or software update to play movies through USB? Or can the Sony people fix my requierment?
Home cinema sony dav f200 error cde c:13:71
ive got a sony dav f200 home cinema system,it lets me play music cds but trying to play dvds(not copied or american) it comes up with and error code c:13:71. what does it mean?
Sony, DAV-C770 only plays in black and white
wrong playback system selection in bouth of tv and DVD player.
please slect auto mode bouth of . and try again.
nuwan
2answers
Movie playing black and white
the problem sounds like its with the s video connection, try using the composite video input
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
